1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Accessing waveform record values in C
To: Andy Foster <[email protected]>, "Wang, Andrew" <[email protected]>
Date: Fri, 19 Feb 2021 16:14:35 +0000
Another way without any C codes: use “subArray” record(s) to extract individual element(s) from a waveform record.
record(subArray, "second_element")
              field(INP, "waveform_record CP")
              field(FTVL, "CHAR")
              field(MALM, "250")
              field(NELM, 1)
              field(INDX, 1)
See this for details (or search other website): https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_SubArray
HTH,
Yong Hu
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Andy Foster <[email protected]>
Date: Thursday, February 18, 2021 at 3:22 AM
To: "Wang, Andrew" <[email protected]>
Hi Andy,
Have you set the field type of field "A" in the aSub record to CHAR? FTA set to CHAR.
Cheers, Andy
On Thu, 18 Feb 2021, 05:23 Wang, Andrew via Tech-talk, <[email protected]> wrote:
All,
Basically I have a waveform record that contains ASCII values of chars shown below.
record(waveform, "waveform_record")
              field(DESC, "")
              field(SCAN, "Passive")
              field(FTVL, "CHAR")
              field(NELM, 250)
When I input caget waveform_record, I get:
waveform_record 250 72 101 108 108 111 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.
My goal is to access 72, 101, 108, 108, and 111 in a C code for an asub record.
record(aSub, "asub_record")
              field(DESC, "")
              field(SNAM, "c_code")
              field(INPA, "waveform_record")
              field(NOA, 250)
In my C code, I attempt to access the waveform record.
char *waveform_record = (char *)prec->a;
printf("%s\n", waveform_record);
The terminal only prints out 72, the first element. But when I try to do
printf("%s\n", *(waveform_record + 4));
I get a segmentation fault rather than 111. Any advice on how I could potentially access the other elements in the waveform record? Feel like I am missing something very basic here.
Andy
RE: Accessing waveform record values in C Dudley, David via Tech-talk
Accessing waveform record values in C Wang, Andrew via Tech-talk
Re: Accessing waveform record values in C Andy Foster via Tech-talk
Prev: LUA: luascript record Kuldeep Joshi via Tech-talk
Next: Alive Server Installation Smith, William via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Accessing waveform record values in C Andy Foster via Tech-talk
Next: RE: Accessing waveform record values in C Dudley, David via Tech-talk
