1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Alive Server Installation
From: "Arms, Dohn A. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Smith, William" <[email protected]>
Date: Fri, 19 Feb 2021 21:07:03 +0000
Hi Will,
I don't know offhand what the problem is, but I'll do a clean install from git and see what might be the issue.
Dohn
From: Tech-talk <[email protected]> on behalf of Smith, William via Tech-talk <[email protected]>
Sent: Friday, February 19, 2021 10:20 AM
To: [email protected] <[email protected]>
Subject: Alive Server Installation
Hi Dohn,
I have been trying to install an alive server (https://epics-alive-server.github.io/). I have followed the various installation files in each repository. First I pulled and installed the alive daemon and ran it successfully. (https://github.com/epics-alive-server/alived)
When I ping it I get:
emil@sissy-serv-04:~/alive$ sudo alivectl -p
up
Next I wanted to install the web server, for that I pulled the following repositories:
https://github.com/dohnarms/dcgi.git
https://github.com/epics-alive-server/client-tools.git
In both directories I did nothing other than “sudo make install”. In both cases I used sudo because the output was being written to /usr/local/ This seemed to work ok, everything was installed and I got no error messages. Finally I pulled the repo https://github.com/epics-alive-server/web-client.git Again I followed the installation instructions, deciding not to change anything because I had installed the requirements in the previous step. This created an executable
/usr/local/cgi-bin/ioc_alive.cgi
If I try and run this
./ioc_alive.cgi
I get the error:
*** buffer overflow detected ***: terminated
Aborted (core dumped)
Any ideas?
All the best,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Alive Server Installation Smith, William via Tech-talk
Prev: Alive Server Installation Smith, William via Tech-talk
Next: RE: Accessing waveform record values in C Dudley, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Matlab 2020b crashes with labCA 3.7.2 Miroslaw Dach via Tech-talk
