1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: pfeiffer TPG 366 Maxiguage Epics support
From: "Oram, Dominic \(STFC,RAL,ISIS\) via Tech-talk" <[email protected]>
Date: Thu, 25 Feb 2021 10:45:26 +0000
Hi Vishnu, Florian,
We also have a number of TPGs, of various models.
The code is very similar to Florian’s but also does some logic for reading the units from the device.
The code can be found at https://github.com/ISISComputingGroup/EPICS-TPG/tree/master/TPGSup, for the unit setting part it also depends on https://github.com/ISISComputingGroup/EPICS-utilities/blob/master/utilitiesApp/Db/unit_setter.template but this is optional.
Feel free to get in touch if you need help setting it up.
Dom
From: Tech-talk <[email protected]> On Behalf Of Florian Feldbauer via Tech-talk
Sent: 24 February 2021 09:44
To: [email protected]
Subject: Re: pfeiffer TPG 366 Maxiguage Epics support
Hey Vishnu,
we use a lot of Pfeiffer equipment and usually use StreamDevice + Asyn for it.
Attached are examples for the TPG 256.
HTH,
Florian
On 2/24/21 10:40 AM, Vishnu Patel via Tech-talk wrote:
Dear All,
     I have Pfeiffer Vacuum gauge  controller TPG366. I would like to read data on serial port(RS-232).
Any one using TPG 366 epics driver and can share with me, I will be very thankful.
Thank you
Vishnu
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
pfeiffer TPG 366 Maxiguage Epics support Vishnu Patel via Tech-talk
Re: pfeiffer TPG 366 Maxiguage Epics support Florian Feldbauer via Tech-talk
Prev: Re: Matlab 2020b crashes with labCA 3.7.2 Till Straumann via Tech-talk
Next: How do I get started with EPICS synApps, asyn and CS-Studio Udit Shah via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: pfeiffer TPG 366 Maxiguage Epics support Florian Feldbauer via Tech-talk
Next: New EPICS User Questions: (1) Microcontrollers (2) Data-data pipeline? Feister, Scott via Tech-talk
