1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: rectangular with visibility not being updated in MEDM
From: Shuei YAMADA via Tech-talk <[email protected]>
Date: Tue, 2 Mar 2021 09:04:50 +0900
Hi Mark,
I tried following three and all of them behave the same wa on SL6:
1) vis="if not zero"
2) vis="calc"  calc=(A>0)"
3) vis="if not zero"  calc=(A>0)"
regards,
Shuei
2021年3月1日(月) 22:00 Mark Rivers <[email protected]>:
> Hi Shuei,
> Your rectangle is defined like this:
> rectangle {
> object {
> x=10
> y=50
> width=120
> height=30
> "basic attribute" {
> clr=53
> "dynamic attribute" {
> vis="if not zero"
> calc="(A>0)"
> chan="TEST:PV1"
> You have a "calc" expression, "(A>0)".  But you have selected vis="if not zero".  I think that if you use a calc expression you should select vis="calc" instead.
> I just tested and either is working OK with Centos7 on your visibility.adl screen.  However, it is worth seeing if changing this fixes the problem for you on Scientific Linux 6.
> Mark
> ________________________________
> From: Shuei YAMADA <[email protected]>
> Sent: Sunday, February 28, 2021 10:53 PM
> To: Mark Rivers
> Cc: [email protected]
> Dear Mark,
> > Can you post a very simple medm screen that shows the problem?  Then we can try to reproduce it.
> Attached adl file is a simple medm screen which I could reproduces the
> problem on Scientific Linux 6. I am trying to make a simple adl file
> to reproduce the problem on CentOS7, but unfortunately I couldn't so
> far.
> I investigated bit further and it seems that the problem emerges when
> a) "text", "text update", and "rectangular with visibility" are placed
> in a medm screen,
> b) and the visibility PV is identical to text update PV,
> c) and the visibility condition is true on medm startup.
> Also I attached 2 screen shots, how one of our medm screens looks like
> on CentOS7 (mainmag-NG.png) and how it is supposed to be
> (mainmag-OK.png). Each box in the screen several rectangles and text
> updates are superpositioned, and some of them are drawn as white box
> or not drawn at all. There are about 500 rectangles and 400 PVs are
> involved.
> best regards,
> Shuei
>                  Shuei Yamada,
>                  High Energy Accelerator Research Organization (KEK)
>                  mailto:[email protected]
                 Shuei Yamada,
rectangular with visibility not being updated in MEDM Shuei YAMADA via Tech-talk
Re: rectangular with visibility not being updated in MEDM Mark Rivers via Tech-talk
Re: rectangular with visibility not being updated in MEDM Shuei YAMADA via Tech-talk
Prev: Job Opportunity - Control Systems Group Leader Forestiero, Suzanne via Tech-talk
Next: EPICS 7.0.5 Released Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: rectangular with visibility not being updated in MEDM Mark Rivers via Tech-talk
Next: Accessing Record fields from asyn driver Torsten Bögershausen via Tech-talk
