1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: weird record names?
From: Alfio Rizzo via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 8 Mar 2021 07:14:07 +0000
Hi Michael,
At ESS we have the convention to have  in a particular position of the record name,
the '#' character for "internal" record, i.e. a record  which is used for instance for intermediate calculations,
In practice this internal record should not be used outside the IOC,
i.e. no channel finder, no archiving , no alarm, no autosave, and so on.
We use as well the '-' and ':'  characters to separate some record name part, e.g.
"Normal" Record Name
Sys-Sub:Dis-Dev-Idx:Prop
"Internal" Record Name
Sys-Sub:Dis-Dev-Idx:#Prop
'#', ':', '- ' as well as '_' are 'legal' or 'illegal' characters ?
Can we use them without the possible risk to have EPICS crashing in any future release ?
Thanks
Best
Alfio
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Michael Davidsaver via Tech-talk
Sent: Saturday, June 13, 2020 5:08 PM
To: Hu, Yong <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Subject: Re: weird record names?
On 6/10/20 9:13 AM, Michael Davidsaver wrote:
> On 6/9/20 6:33 PM, Hu, Yong wrote:
>> Michael,
>> When you say "restrictions", does that mean a newer version of EPICS IOC will fail to load a .db file in which a record name contains a "weird" character?
> Eventually, yes.  That is what I'm considering.
cf. for a concrete proposal.  https://github.com/epics-base/epics-base/pull/78
>> If the IOC fails to load .db because it does not follow the new rules/restrictions, facilities that have already used "weird" characters will suffer badly when they upgrade EPICS base to a newer version.
> I recognize and want to avoid this.
> Any new restriction would begin as a warning, and likely remain so for
> a number of years.
> This would mainly serve as an early indication of names which would
> cause problems in other contexts.  Record names which would be
> impossible in link to (like "a b" below, or "123"), or which would
> never parse as channel names (like "x.y").
> 3.15.0.1 introduced a warning for record names containing " \"'.$".
> These might now begin to be enforced.  And include "\t" for good
> measure.
>> Yong
>> On 6/8/20, 5:09 PM, "Tech-talk on behalf of Michael Davidsaver via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
>>     I'm looking to collect examples of epics record names in the wild.
>>     This is an early step towards (maybe) adding restrictions on what
>>     characters a record name can contain, and in what positions.
>>     eg. restricting possible first and last characters.
>>     In particular I'm looking for examples including characters
>>     beyond the usual alphanumeric separated by ':' or '-'.
>>     And in what positions they may (or may not) appear.
>>     An example from the NSLS2 naming convention (for which I am have
>>     some responsibility).
>>     > TST{evm:1D-DlyGen:31}Evt:Trig2-SP
>>     Which is notable for containing "{" and "}" in the middle.
>>     As background.  At present, records can be created with almost
>>     any characters in a name.
>>     > record(ai, "a b") {}
>>     > record(ai, "x.y") {}
>>     > record(ai, "x\"") {}
>>     However, record names including '.' can't be addressed and aren't
>>     very useful.  Further, names including spaces can't be targeted
>>     by links.
>>     On the subject of links.  Dirk was surprised to find that
>>     the syntax for link parsing treats "[0]" as a record name,
>>     but "[0,1]" as a constant array.
>> https://urldefense.com/v3/__https://bugs.launchpad.net/epics-base/*bu
>> g/1882520__;Kw!!P4SdNyxKAPE!TwNJ4RpksYZmN8YbfgjiN7Y3igc4486VOLcj-_1L1
>> KUqPcMdbvxVXH_bSrI3$
>>     Rather than carving out another exception, I'd like to look at
>>     coding a general rule.
Re: weird record names? Johnson, Andrew N. via Tech-talk
Prev: Re: Error executing a sample Arduino IOC Michael Davidsaver via Tech-talk
Next: Re: weird record names? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
