1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Writing/Reading PVs from/to a DB Question
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
Date: Wed, 10 Mar 2021 23:30:45 +0000
Hello All,
I have a few questions about access to PVs from an outside DB and CSS
  1. Is there an option to read/write directly to a PV from a database such as rethinkdb or mariadb?
  2. Is there an option for an IOC to read from a DB and then write to the PVs and also write back to the DB?
  3. I did see an option for CSS to connect to a DB through the JDBC, I assume this can read/write from/to that DB or is there another possible way through CSS?
  4. With CSS is it possible to read in a file JSON/XML/Flat to populate GUI elements that then write to their corresponding PVs and in reverse write out to a file?
Adam
Re: Writing/Reading PVs from/to a DB Question Johnson, Andrew N. via Tech-talk
Prev: StreamDevice with waveforms Randall Cayford via Tech-talk
Next: Re: StreamDevice with waveforms Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: StreamDevice with waveforms Johnson, Andrew N. via Tech-talk
Next: Re: Writing/Reading PVs from/to a DB Question Johnson, Andrew N. via Tech-talk
