1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: New to EPICS - v4 questions
To: Stainer Tom <[email protected]>
Date: Thu, 11 Mar 2021 13:40:29 +0000
Hi Tom,
> Mark you touched upon areaDetector, which indeed looks useful, but how does one get started with the modules?
There is documentation for areaDetector here:
https://areadetector.github.io/master/index.html
It includes an installation guide and a user guide that documents each of the plugins and the detector drivers.
There are training materials (videos and slides) for areaDetector available here:
https://www.bnl.gov/ps/epics/
https://epics.anl.gov/docs/APS2015.php
To get started you typically will have one type of camera or detector you would like to use.  For example, if it is a FLIR/Point Grey camera that you want to run with ADSpinnaker on Linux need to download and build:
- EPICS base
- The following repositories from the areaDetector project: areaDetector, ADCore, ADSupport, ADGenICam, and ADSpinnaker.
- The following repositories from epics-modules.  asyn, autosave, busy, calc, iocStats, sscan.
When you build ADSpinnaker it builds an EPICS IOC application.  That is often all you need, and on my EPICS installations at beamlines we only use the IOC applications that are built with each detector.  You can also build a custom application if you want, where that camera driver is combined with other drivers, for example for motors, beam position monitors, etc.
> Do you typically adopt them on a need by need basis?
I'm not sure what you mean by "adopt them".  As I said above many sites just run the applications that are built with each detector.  Some sites add their own custom plugins and do other modifications, but it is often not necessary.  The areaDetector IOC applications are highly customizable without doing any programming or recompiling, since the plugins can be selected and wired together in the desired configuration at run-time.
> Specifically is there any documentation and/or examples on how these modules all relate to each other and how they are generally used in production?
Do you mean the different modules in areaDetector?  If so, then here is a quick summary:
- ADSupport provides third-party libraries (TIFF, JPEG, HDF5, XML2, etc.) packaged so they build with the EPICS build system for most supported EPICS architectures (Linux, Windows, Mac, vxWorks, etc.)
- ADCore provides the basic framework and all of the common plugins for image manipulation, file saving, etc.
- ADxxx provides the driver for a specific detector xxx.
- ADViewers provides pvAccess and Channel Access clients for real-time display and analysis of the images from the detector.
From: Tech-talk <[email protected]> on behalf of Stainer Tom via Tech-talk <[email protected]>
Sent: Thursday, March 11, 2021 4:14 AM
To: [email protected]
Subject: RE: New to EPICS - v4 questions
Thanks Kay and Mark!
I appreciate the extensive response, very helpful. It is clear that I cannot go full PVA yet.
I must say that the API for PVXS is somewhat cleaner and easier to use, but the documentation and examples for pvAccess + pvDatabase makes it easier to get started with.
With respect to the “vision” of EPICS and the longer term plan (if there is such a thing), what are the intentions with regard to support and endorsement?
- For example, is Phoebus going to fully superseed CSS?
- What functionality is missing, if any, from Phoebus which is currently supported by CSS?
- Is there any intention to deprecate pvAccess et al in favour of PVXS or will the two coexist?
Besides epics-base and the CA vs PVA debate, the plethora of modules available in EPICS is also somewhat daunting to a new user. Mark you touched upon areaDetector, which indeed looks useful, but how does one get started with the modules? Do you typically adopt them on a need by need basis? Specifically is there any documentation and/or examples on how these modules all relate to each other and how they are generally used in production?
Maybe the some of my questions are too broad but it would be nice to know what people are using out in the wild…
Kind regards,
Tom
Sent: Friday, March 5, 2021 6:33 PM
To: 'Kasemir, Kay' <[email protected]>; Stainer Tom <[email protected]>
Cc: [email protected]
Kay, thanks for the very nice summary.
I’ll just add a few more reasons for using PVAccess for areaDetector NDArrays.
-          The data type of the array seen by the PVAccess client will change dynamically as the source data type changes.  One example is when a camera is switched between 8-bit and 16-bit modes.
-          PVAccess supports data compression.  areaDetector NDPluginCodec and the ImageJ and Python viewers support the blosc, lz4, bitshuffle/lz4, and jpeg codecs.
-          PVAccess provides all of the additional NDAttribute metadata associated with the array.  These might include the storage ring current, the camera exposure time, etc.
From: Tech-talk <[email protected]<mailto:[email protected]>> On Behalf Of Kasemir, Kay via Tech-talk
Sent: Friday, March 5, 2021 10:48 AM
To: [email protected]<mailto:[email protected]>; Stainer Tom <[email protected]<mailto:[email protected]>>
Good questions.
At this time, I think the answers all describe an in-between scenario.
Bottom line is that there's no need to panic.
Simply use EPICS IOCs as they have always been used, with Channel Access.
All the IOCs and all the client tools fully support that.
If you create an IOC with a recent EPICS 7 release, it will by default also include a PVAccess server.
At this time, you can probably safely ignore that, but keep it enabled to be ready for the future.
Some clients can already switch to PVAccess, and for the most part that works the same as Channel Access, but right now there's likely no reason to fully switch over.
There are two scenarios where using PVAccess offers big advantages:
When you use the AreaDetector to serve images, doing that over PVAccess means that one PV carries not only the bits in the image but also metadata like size, color mode. So new clients can right away display the image. With Channel Access, the image PV only has the bits, and you need to configure many clients manually to tell them about the image size etc. PVA is also faster for images than Channel Access.
The other advantage of PVA is when you write your own, non-IOC server for custom data. With PVA, you can transfer your own custom data structures, which you couldn't do with CA. There are demonstrations for combining fields of "normal" records into such custom structures, but I think it's fair to say that we're still exploring how that would be used and what it should look like in the final incantation. This would not be a time to replace all your basic records and PVs with custom structures just for the fun of it.
At this time a full switch to PVA is likely limited by not all tools fully supporting it, and the absence of a well-tested network gateway. The one that's in common use for example uses new UDP ports when replying to search requests. Can't use that via a firewall.
You'll also notice that we just developed a second set of server and client libs for C++ and Java. While the first ones were great for demonstrating the protocols and figuring several details out, the "updates" focus on the specific advantages of C++ (pvxs) respectively Java (as used in CS-Studio/phoebus), so they have an API that's more natural to those who use C++ resp. Java, while the original implementations concentrated on offering the exact same API, thus ending up with the lowest common denominator of the two languages.
Bottom line, for an "end user" I'd suggest to keep PVA 'enabled', maybe try it for Area Detector images, and be prepared to eventually switch over, but for now concentrate on CA for most of the PV traffic.
-Kay
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Stainer Tom via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Friday, March 5, 2021 11:10 AM
To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>>
Subject: [EXTERNAL] New to EPICS - v4 questions
I am new to EPICS and to the community and therefore I apologise in advance if my question is somewhat elementary, but I have been struggling to understand EPICS v4 fully from documentation alone.
It is quite clear that most documentation available online is focused on Channel Access and EPICS v3, however, since I am new to EPICS I would like to start learning from the latest (and greatest?) version and protocol i.e v4 & PVAccess. I understand that v7 supports both CA and PVA, that is clear, but what is not so clear is how to use PVAccess when compared to CA.
For example, I have come across the exampleCPP repository (https://github.com/epics-base/exampleCPP) focused on defining records, servers, and clients, using the pvDatabase and pvAccess interfaces. In addition, I have also come across the PVXS library (https://github.com/mdavidsaver/pvxs) which offers an alternative approach to this (and seems to avoid the concept of record and databases altogether?). While there are some nice examples and some short explanations of each it has still been a struggle to figure out how they work and to understand how it relates to the v3 approach. The same goes for the python packages: pyepics, pvapy and p4p (and others). As a newcomer it is quite confusing to see many different approaches and packages used but no clear entry point on which one should be used in different circumstances, and which libraries/packages support which functionality i.e. access control, etc.
My initial questions are:
•         Is PVXS intended to replace pvDatabase, pvAccess et al?
•         Of the C++ and Python packages & libraries which ones are most feature complete in terms of the v3 approach?
•         What is the best way to get started and start building clients, servers, IOCs?
•         How does PVA and the nested datastructures work with the process database (file based record definition)?
•         Going forward which packages are likely to be maintained and supported on both the C++ and python sides?
•         Can I altogether ignore v3 and Channel Access when starting from scratch and just use v4 for everything? Is this the recommended approach for newcomers? Are there any limitations to using v4 compared to v3?
Any help you can provide on this is much appreciated.
Kind regards,
Tom
RE: New to EPICS - v4 questions Stainer Tom via Tech-talk
Re: New to EPICS - v4 questions Kasemir, Kay via Tech-talk
RE: New to EPICS - v4 questions Mark Rivers via Tech-talk
Prev: RE: New to EPICS - v4 questions Stainer Tom via Tech-talk
Next: Re: New to EPICS - v4 questions Marty Kraimer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: New to EPICS - v4 questions Stainer Tom via Tech-talk
