1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Beatnik RTEMS4.10.2 vmeTsi148 ISR: ERROR: no handler registered
To: Talk EPICS Tech <[email protected]>, "[email protected]" <[email protected]>, rt-swg <[email protected]>
Date: Thu, 11 Mar 2021 17:35:33 -1000
It looks like the IRQEntry vector triggering this interrupt was null. I'm not sure what condition would arise leading to this.
Maybe memory corruption or a bus error.
On Thu, Mar 11, 2021 at 2:42 PM Matt Rippa <[email protected]> wrote:
Hello,
Our Primary Mirror control system has a beatnik bsp running on a mvme6100 with RTEMS4.10.2 and EPICS 3.14.12.8 (which understandably is not actively supported). We've experienced a single event that we've never seen before. vmeTsi148 ISR: ERROR: no handler
After this it appears all interrupts were disabled and the VME bus communications are down. This system is normally well behaved with uptimes measured in months. In 2020 we had an uptime of 301 days!
Has anyone seen an error like this on the beatnik bsp?
Subsequent to the error which corresponds closely with a casr command, we see dbScan warnings in our logs. These persisted several times per minute until the system was reboot.
Thanks for any insight.
-Matt Rippa
<8/3/2021 8:00:32 hst>pcs-mk-ioc> casr
<8/3/2021 8:00:33 hst>Channel Access Server V4.13
<8/3/2021 8:00:33 hst>Connected circuits:
<8/3/2021 8:00:33 hst>TCP xxxxxxxxxxxxxxxxxxxx, V4.13, 6 Channels, Priority=0
xxxxxxxxxxxxxxxxxxxx, V4.13, 134 Channels, Priority=80
<8/3/2021 8:00:33 hst>TCP , V4.13, 1 Channels, Priority=0
<8/3/2021 8:00:33 hst>TCP , V4.13, 5 Channels, Priority=0
<8/3/2021 8:00:33 hst>TCP , V4.13, 8 Channels, Priority=0
<8/3/2021 8:00:33 hst>TCP , V4.13, 60 Channels, Priority=0
<8/3/2021 8:00:33 hst>TCP , V4.13, 9 Channels, Priority=0
<8/3/2021 8:00:34 hst>TCP , V4.13, 9 Channels, Priority=0
<8/3/2021 8:00:34 hst>TCP , V4.13, 71 Channels, Priority=0
<8/3/2021 8:00:34 hst>TCP , V4.13, 5 Channels, Priority=0
<8/3/2021 8:00:34 hst>TCP , V4.13, 359 Channels, Priority=20
<8/3/2021 8:00:34 hst>TCP , 741 Channels, Priority=20
<8/3/2021 8:00:34 hst>TCP , V4.13, 5 Channels, Priority=20
<8/3/2021 8:00:34 hst>pcs-mk-ioc> vmeTsi148 ISR: ERROR: no handler registered (level 2) IACK 0x00000045 -- DISABLING level 2
<8/3/2021 8:05:14 hst>vmeTsi148 ISR: ERROR: no handler registered (level 4) IACK 0x00000040 -- DISABLING level 4
<8/3/2021 8:34:54 hst>dbScan warning from '.2 second' scan thread:
<8/3/2021 8:34:54 hst>        Scan processing averages 0.300 seconds (0.300 .. 0.300).
<8/3/2021 8:34:54 hst>        Over-runs have now happened 10 times in a row.
<8/3/2021 8:34:54 hst>        To fix this, move some records to a slower scan rate.
<8/3/2021 8:35:09 hst>dbScan warning from '.2 second' scan thread:
<8/3/2021 8:35:09 hst>        Scan processing averages 0.300 seconds (0.300 .. 0.300).
<8/3/2021 8:35:09 hst>        Over-runs have now happened 10 times in a row.
<8/3/2021 8:35:09 hst>        To fix this, move some records to a slower scan rate.
Re: Beatnik RTEMS4.10.2 vmeTsi148 ISR: ERROR: no handler registered Johnson, Andrew N. via Tech-talk
Beatnik RTEMS4.10.2 vmeTsi148 ISR: ERROR: no handler registered Matt Rippa via Tech-talk
Prev: Beatnik RTEMS4.10.2 vmeTsi148 ISR: ERROR: no handler registered Matt Rippa via Tech-talk
Next: Re: Beatnik RTEMS4.10.2 vmeTsi148 ISR: ERROR: no handler registered Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
