1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Open additional resources as a separate window(not tab) in CSS-Phoebus server mode
From: "Usmani, Imran Ali via Tech-talk" <[email protected]>
Date: Mon, 15 Mar 2021 19:31:10 +0000
Hi everyone,
I am looking for a cmd line option to open additional resources as a separate window(not as a separate tab in the main window) in server mode for CSS-Phoebus.
I can start CSS-phoebus with:
# /bin/java  -jar  phoebus/target/product-4.6.3.jar -server 4918
Now I can open file xyz.plt with databrowser app on same css-phoebus server using:
# /bin/java  -jar  phoebus/target/product-4.6.3.jar -server 4918 -resource xyz.plt
This opens a databrowser tab in the main css-phoebus UI window.
I want a command(from bash) to open this resource as a separate window not as a separate tab in main UI window.
It should be on the same css-phoebus server, not on a new phoebus instance.
The reason I need to open this as a separate window is because
I want a create bash script which opens multiple resources on a single css-phoebus server in different linux work spaces.
PS: I can open each resource as a separate css-phoebus instance(in non-server mode), I don't want that because it will be slow and memory intensive.
Imran
Re: Open additional resources as a separate window(not tab) in CSS-Phoebus server mode Kasemir, Kay via Tech-talk
Prev: Existing device support Sinclair, John via Tech-talk
Next: Re: Open additional resources as a separate window(not tab) in CSS-Phoebus server mode Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Existing device support Abdalla Ahmad via Tech-talk
