1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: SIS3316 or other fast, high-resolution digitizer support
From: Heinz Junkes via Tech-talk <[email protected]>
Date: Thu, 18 Mar 2021 08:20:49 +0100
Good morning Mark,
I have a support for it which I am currently testing intensively under RTEMS and EPICS7 (incl. pvAccess).
It should go into production on Monday. I will put it in git this weekend and you can have a look at it then.
It should also run under VxWorks. Also uses asyn ;-)
Gruss Heinz
P.S. I now use the VMEbus with MVME6100
P.P.S The software that uses the GigE port has been running on Linux for a while now.
> On 18. Mar 2021, at 00:33, Mark Rivers <[email protected]> wrote:
> Folks,
> I am interested in finding out about EPICS support for the SIS3316-250-14 or SIS3316-125-16 digitizers.  These are 250 MSample/s 14-bit and 125 MSamples/s 16-bit respectively.  I saw that in 2015 Heinz Junkes said he had a driver that used the GigE interface on the card.  Is there a vxWorks driver?
> Alternatively are there other digitizers with similar specs that have EPICS support?
> Thanks,
> Mark
Attachment: smime.p7s
Description: S/MIME cryptographic signature
SIS3316 or other fast, high-resolution digitizer support Mark Rivers via Tech-talk
Prev: 8671B Synthesized CW Generator (GPIB) Ernesto Paiser via Tech-talk
Next: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: SIS3316 or other fast, high-resolution digitizer support Mark Rivers via Tech-talk
Next: 8671B Synthesized CW Generator (GPIB) Ernesto Paiser via Tech-talk
