1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Subject: Re: MRF kernel module, failed to map BARS
From: Lucas Russo via Tech-talk <tech-talk at aps.anl.gov>
To: GAGET Alexis <alexis.gaget at cea.fr>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 23 Mar 2021 15:22:42 -0300
Hi Alexis,
I have a similar setup (NAT R2 and R9 crates, with NAT COMEX CPUs), CentOS 7 (but with newer kernel: 4.4.128-1.el7.elrepo.x86_64) and I think I remember having similar issues.
I think, If I remember correctly, that the following kernel boot parameters helped with this issue:
GRUB_CMDLINE_LINUX="crashkernel=128M rd.lvm.lv=centos/root rd.lvm.lv=centos/swap rhgb quiet pciehp.pciehp_force=1 pciehp.pciehp_debug=1 pcie_ports=native pci=realloc,noaer"
Particularly the pci/pcie options helped with the hot-plugging support.
Maybe this will help,
Cheers,
Lucas
On Tue, Mar 23, 2021 at 12:35 PM GAGET Alexis via Tech-talk <tech-talk at aps.anl.gov> wrote:
Dear All,
Here at saclay we are using MRF timing system with MTCA.4 in R2 NAT crate.
I’m using the COMex-E3 and a MCH-PHYS80. The IOC using the mrfioc2 driver is running on the Comex and the mrf kernel module is loaded on it. I have forked from ESS version of mrfioc2, and the kernel module I built seems the same.
My kernel version is : 3.10.0-1160.15.2.el7.x86_64 on a CenTOS Linux 7.9.2009
It works globally very well, but I have a reproducible issue:
When I reboot the whole R2 crate and when I load the MRF kernel module I have the following message :
 [  347.344081] mrf: module verification failed: signature and/or required key missing - tainting kernel
[  347.345504] mrf-pci 0000:04:00.0: Attaching MRF device w/o PLX bridge (00007011)
[  347.345581] mrf-pci 0000:04:00.0: can't ioremap BAR 0: [??? 0x00000000 flags 0x0]
[  347.345646] mrf-pci 0000:04:00.0: Failed to map BARS! 0 0
[  347.345918] mrf-pci 0000:06:00.0: Attaching MRF device w/o PLX bridge (00007011)
[  347.345989] mrf-pci 0000:06:00.0: can't ioremap BAR 0: [??? 0x00000000 flags 0x0]
[  347.346053] mrf-pci 0000:06:00.0: Failed to map BARS! 0 0
Consequence, my Comex can’t find some of my EVR or EVM (some are found..).
To make it work I just have to reboot the Comex and after that it’s working. Meaning after a shutdown I have to reboot it twice…
Does anyone have this kind of trouble ? Knows how to solve it ? or even understand this message ?
Thanks for your consideration
Alexis GAGET
CEA Saclay - DRF/Irfu/DIS/LDISC
Bâtiment 472 – pièce 105
01 69 08 95 17
MRF kernel module, failed to map BARS GAGET Alexis via Tech-talk
Prev: MRF kernel module, failed to map BARS GAGET Alexis via Tech-talk
Next: Support for CAEN DT5730 / DT5730S? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Next: Fwd: MRF kernel module, failed to map BARS Jeong Han Lee via Tech-talk
ANJ, 23 Mar 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
