1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Possible to Populate CSS text fields with JDBC calls?
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>
Date: Thu, 25 Mar 2021 18:08:48 +0000
Hi Ralph,
Appreciate the advice, I wouldn’t say I just bumped into CSS as I have been developing with it and documentation on Phoebus is difficult to come by (a lot seems linked to the old version BOY).  Hence the reason to reach out to Kay and I add in tech talk since I have learned a lot by just reading through others forum posts instead of just reaching out to Kay directly.   I will try to generalize my question a bit more for people.
Looking for options to automate filling in of PVs from database values given an input from a user on a Phoebus GUI.
Adam
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Thursday, March 25, 2021 10:51 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Possible to Populate CSS text fields with JDBC calls?
Hi Adamandios,
Allow me a more general comment:
For queries to Tech-Talk, I found it more efficient in the past to describe the problem you're trying to solve than asking a specific question about the thing/tool that you just bumped your head into.
By doing that, you motivate colleagues that have developed neat solutions for similar problems to come forward and showcase what they have done. Not only will you probably find in the answers at least one or two ideas worth pursuing - the other colleagues on the list will also receive them, consider the options and may benefit later on.
Asking the specific question, only the specialist will be able to answer, there's a good chance you get a "No way. But why do you want that, anyway?", and the added benefit for the rest of the list is small.
Cheers,
~Ralph
Re: Possible to Populate CSS text fields with JDBC calls? Kasemir, Kay via Tech-talk
Possible to Populate CSS text fields with JDBC calls? Manoussakis, Adamandios via Tech-talk
RE: Possible to Populate CSS text fields with JDBC calls? Manoussakis, Adamandios via Tech-talk
Re: Possible to Populate CSS text fields with JDBC calls? Ralph Lange via Tech-talk
Prev: Re: Possible to Populate CSS text fields with JDBC calls? Ralph Lange via Tech-talk
Next: Re: Possible to Populate CSS text fields with JDBC calls? Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
