1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Phoebus lock down BOB
From: Stainer Tom via Tech-talk <[email protected]>
Date: Mon, 29 Mar 2021 12:50:53 +0000
>> But it still opens CSS in the same way as opening the BOB file - I can edit the OPI and from the user point of view it is still Phoebus not a single page application that is locked down.
>When you run phoebus, you can't do much about the fact that that's what you're running.
> If you want something else, you'll have to use something else, for example the web runtime, which will only display/execute *.bob files, without an editor, without a data browser, without probe, pv tree  etc.
> You can also assemble your own site-specific version of phoebus where you simply don't include the display editor.
> Then you won't be able to invoke the editor, so you'll likely need to build two versions:
> One that includes the editor so you can create displays, and one without the editor for you end users to have an execute-only version.
> As a test, you can simply delete the file lib/app-display-editor-*.jar from the product.
> -Kay
That's clear, thanks for clarifying.
Kind regards,
Tom
Re: Phoebus lock down BOB Tynan Ford via Tech-talk
Phoebus lock down BOB Stainer Tom via Tech-talk
Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
RE: Phoebus lock down BOB Stainer Tom via Tech-talk
Prev: Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
Next: modbus read error Дмитрий Прощенко via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Phoebus lock down BOB Tynan Ford via Tech-talk
