1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: modbus read error
To: 'Дмитрий Прощенко' <[email protected]>
Date: Mon, 29 Mar 2021 17:05:42 +0000
Your db and st.cmd files look OK except perhaps for this:
modbusInterposeConfig("PSU0",1,300,4)
That sets a timeout of 300 ms for receiving a reply from the device.  That may be too short, I suggest increasing that to 2000.
You should enable asynTrace on the serial port so that you can see the full communication between the IOC and the device.
Add these lines to your st.cmd right after modbusInterposeConfig()
asynSetTraceIOMask("PSU0",0,”HEX”)
asynSetTraceMask(“PSU0”,0,”ERROR|DRIVER”)
Once you do that please send the complete output when the IOC boot and runs for 20 seconds or so.
From: Tech-talk <[email protected]> On Behalf Of ??????? ???????? via Tech-talk
Sent: Monday, March 29, 2021 8:13 AM
To: [email protected]
Subject: modbus read error
Hi all, Im a student and a beginner in EPICS.
I am currently developing an IOC to drive a power supply (PS) via Modbus RTU. Using lib modbus R3-2.
I have a problem with DO reading, DO writing is successful. I can see, PS receives message and answers (what I dont know).
I thought there was a mistake in the argument in function in st.cmd, but I tested modbus start address and slave address in Modpoll.
Also asynReport was used, and according to it: ....name=IO_ERRORS, value=49,...... (depends on run time)
My error:
TEST-MSC-FUN:COIL-ONOFF-GET devAsynUInt32Digital::processCallbackInput process read error.
and sometimes:
drvModbusAsyn::doModbusIO port SET writeRead status back to normal having had 1 errors, nwrite=6/6, nread=5
What shout I pay attention to?
Its my db:
record (bi,"TEST-MSC-FUN:COIL-ONOFF-GET")
field(DESC, "Ctrl on/off PSU")
field(DTYP, "asynUInt32Digital")
field(INP, "@asynMask(GET 1 0x1) MODBUS_DATA")
field(ONAM, "ON")
field(SCAN, "1 second")
field(ZNAM, "OFF")
record (bo,"TEST-MSC-FUN:COIL-ONOFF-SET")
field(DESC, "ON OFF PSU")
field(ONAM, "ON")
field(OUT, "@asynMask(SET 1 0x1)")
field(ZNAM, "OFF")
Its my st.cmd:
callbackParallelThreads
drvAsynSerialPortConfigure("PSU0", "/dev/ttyS1", 0, 0, 0)
asynSetOption("PSU0",0,"baud","57600")
asynSetOption("PSU0",0,"parity","none")
asynSetOption("PSU0",0,"bits","8")
asynSetOption("PSU0",0,"stop","1")
# Function code=1
drvModbusAsynConfigure("GET", "PSU0", 1, 1, 0, 300, 0, 500, "PSU")
# Function code=5
drvModbusAsynConfigure("SET", "PSU0", 1, 5, 0, 128, 0, 1000, "PSU")
modbus read error Дмитрий Прощенко via Tech-talk
Prev: Re: Rate of change calculation Arnold, Ned D. via Tech-talk
Next: Question about ACROMAG IP-408 Wang, SuYin Grass via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: modbus read error Дмитрий Прощенко via Tech-talk
