1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Usage of an EPICS word
From: "jun-ichi.odagiri--- via Tech-talk" <[email protected]>
To: "EPICS Tech Talk" <[email protected]>
Date: Tue, 30 Mar 2021 12:49:16 +0900
Dear Ralph,
I make a correction.
> What I wanted to do was to give "CAS-client" a priority
> higher than that of "scan-0.1" because commands sent from
> a CA client to an IOC start to be lost when the number of
> records being processed with the SCAN value of ".1 seconds"
> was increased.
The problem was not loss of CA messages but some funny
behavior of the device under EPICS control. I made many
mistakes since I'm now very impatient and confused because
the deadline is approaching very close.
To all.
I apologize to all of you if "you" in Ralph's mail does
not mean me.
J.Odagiri at KEK in a hurry
----- Original Message -----
> Dear Ralph,
> I assume that "you" means me in your message because I
> triggered this chain of e-mails. If not, please just ignore
> this e-mail.
> (I know "you" can mean unspecified persons in English.)
> was increased.
> But now I understand that the problem of mine is not an
> issue of priorities of threads but an issue of something
> else.
> (I think default priorities of the EPICS IOC threads
> are well-chosen as you mentioned in a previous e-mail.)
> I do not want to choose multiple IOCs solution because
> I want to keep the system as simple as possible.
> The value of PRIO field is irrelevant because I do not
> rely on callback threads in my device support.
> I can not choose multiple parallel callback solution
> because my system is single-CPU system.
> I now suspect that the origin of my problem is not on
> IOC-side but on a custom device-side being controlled
> by the IOC.
> Lots of thanks anyway for your detailed comments and
> advice.
> Best regards,
> J.Odagiri at KEK
> > So, coming back to what (I think) was the original question:
> > How to change the priority of the general purpose callback threads (
> named
> > "cb...") to be higher than a periodic scanning thread?
> > You don't have to. Use the PRIO field.
> > There are three (sets of) general purpose callback threads, related
to
> the
> > three values of the records' PRIO field: Low, Medium and High.
> > Their priorities are designed to be lower than all periodic
processing
> > (Low), halfway between the slow and the fast periodic processing (
> Medium)
> > and higher than all period processing (High). For each record, the
> thread
> > used for callback processing is selected based on the setting of its
> PRIO
> > field.
> > On multi-CPU systems, you can also enable multiple parallel callback
> > threads (e.g., one per CPU) to boost the callback and 'I/O Intr'
> processing
> > power of your IOC.
> > Only if these mechanisms show not being sufficient for your
> application,
> > additional steps need to be taken. In most cases, I would assume
> further
> > parallelization (splitting up the application to multiple IOCs,
adding
> more
> > CPU power) to be more efficient than tuning priorities.
> > Cheers,
> > ~Ralph
Usage of an EPICS word jun-ichi.odagiri--- via Tech-talk
Re: Usage of an EPICS word Mark Rivers via Tech-talk
Re: Usage of an EPICS word Ralph Lange via Tech-talk
Re: Usage of an EPICS word jun-ichi.odagiri--- via Tech-talk
Prev: Re: Changing EPICS general Purpose Thread's Priorities Jeong Han Lee via Tech-talk
Next: Questions about arrays Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Usage of an EPICS word jun-ichi.odagiri--- via Tech-talk
Next: CS-Studio Databrowser historical data display Vishnu Patel via Tech-talk
