1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Questions about arrays
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>, "Wang, Andrew" <[email protected]>
Date: Tue, 30 Mar 2021 15:31:24 +0000
Hi Andrew,
It's clunky and inefficient, but problem (1) can be solved with an acalcout record.  If AA=[0,1,2,3,4,5], and A=20, then the _expression_ "cat(cat(aa[0,2],a),aa[3,5])" yields AVAL=[0,1,2,20,4,5]
Even more horrifying, problem (2) can also be solved with an acalcout record.  If A==1, B==2, etc., up to H==8, then the _expression_ "aa:=a;k:=0;j:=until(aa:=cat(aa[0,k],@(k+1));k:=k+1;k==9);aa" yields AVAL=[1,2,3,4,5,6,7,8,0,...].
I'm sure there are better solutions, but sometimes it's ok to do something clunky for the moment, so you can move on to the next part of the problem.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Wang, Andrew via Tech-talk <[email protected]>
Sent: Monday, March 29, 2021 10:55 PM
Subject: Questions about arrays
All,
I have two questions pertaining to the array records in EPICS 3.15.
  1. Suppose I have an analog input array or waveform record of size 5 that contains the values 1, 2, 3, 4, 5. Suppose I want to replace with the fourth element. Based upon what I've read, it doesn't seem like subArray is a viable choice. I've also tried to use caput but to no avail. Any recommendations other than using aSub?
  2. Suppose I have eight individual analog input records and I want to "concatenate their values" and store the result into an analog input array record. I'm thinking about using either aCalcout or an aub routine. Are those valid options and if not, what are alternative options I should explore?
Thank you!
Andy
Re: Questions about arrays Hu, Yong via Tech-talk
Questions about arrays Wang, Andrew via Tech-talk
Prev: RE: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
Next: Re: Questions about arrays Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Questions about arrays Wang, Andrew via Tech-talk
Next: Re: Questions about arrays Hu, Yong via Tech-talk
