1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: RE: CentOS8--An error occurred when installing StreamDevice
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: 回忆回眸 <liu1516301092 at foxmail.com>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Thu, 1 Apr 2021 16:54:09 +0000
I forgot to include tech-talk in my original reply.
> Among them “asyn” has been installed and the asyn installation path is configured in configure/RELEASE.
It really seems like there is a problem with your configure/RELEASE file.  If asyn were defined there then it should be in the list of include paths.  I have broken the output of your compile command so each -I starts on a new line to make it easier to read.
-I.
-I../O.Common
-I.
-I.
-I..
-I../../include/compiler/gcc
-I../../include/os/Linux
-I../../include
-I/home/lytt/epics/base/include /compiler/gcc
-I/home/lytt/epics/base/include/os/Linux
Note that it is not searching the asyn directory.
This is what I get when I compile on Centos8:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -DUSE_TYPED_RSET -DSTREAM_INTERNAL   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common
-I.
-I.
-I..
-I../../include
-I/corvette/home/epics/devel/asyn-4-41/include
-I/corvette/home/epics/devel/calc-3-7-3/include
-I/corvette/usr/local/epics-devel/base-7.0.5/include/compiler/gcc
-I/corvette/usr/local/epics-devel/base-7.0.5/include/os/Linux
-c ../AsynDriverInterface.cc
Note that it is searching in asyn-4-41.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of 回忆回眸 via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, April 1, 2021 1:50 AM
To: tech-talk
Subject: CentOS8--An error occurred when installing StreamDevice
Hello, I got the following error when installing StreamDevice:
Compilation is interrupted.
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -DUSE_TYPED_RSET -DSTREAM_INTERNAL -O3 -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I.- I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/home/lytt/epics/base/include /compiler/gcc -I/home/lytt/epics/base/include/os/Linux -I/home/lytt/epics/base/include -c ../AsynDriverInterface.cc
../AsynDriverInterface.cc:41:10: Fatal error: asynDriver.h: No such file or directory
  #include "asynDriver.h"
    Among them “asyn” has been installed and the asyn installation path is configured in configure/RELEASE. How can I solve this? Thank you!
CentOS8--An error occurred when installing StreamDevice =?gb18030?b?u9jS5LvY7fg=?= via Tech-talk
Prev: Re: Questions about arrays Ralph Lange via Tech-talk
Next: RE: Question on Multiple Instruments in one IOC or Multiple IOCs for each Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: CentOS8--An error occurred when installing StreamDevice Johnson, Andrew N. via Tech-talk
Next: Re: 回复: CentOS8--An error occurred when installing StreamDevice Mark Rivers via Tech-talk
ANJ, 02 Apr 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
