1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: 回复:RE: 回复: 回复: CentOS8--An error occurred when installing StreamDevice
To: 回忆回眸 <[email protected]>
Date: Fri, 2 Apr 2021 14:16:46 +0000
> make[2]: *** There is no rule to make the target "../../lib/linux-x86_64/libpcre.a", which is required by "libstream.so".
Your original RELEASE file contained this.
Ø  PCRE=$(SUPPORT)/streamdevice/StreamDevice-master/prce/prce2-10.36
This seems strange because you have put the pcre module under StreamDevice-master.  It really should be at the same level as asyn, calc, streamdevice, etc.  Then you need to build pcre first, and correctly define its location in StreamDevice-master/configure/RELEASE.
Alternatively you can just install the package that contains libpcre.so on your Linux system, and then you don’t need to build it.  That is what I have done.
Sent: Friday, April 2, 2021 9:01 AM
To: Mark Rivers
Subject:
I did it again according to your first method, and finally it can be compiled. But an error occurred.
/usr/bin/ranlib libstream.a
make[2]: *** There is no rule to make the target "../../lib/linux-x86_64/libpcre.a", which is required by "libstream.so". Stop.
make[2]: leave the directory "/home/lytt/epics/streamdevice/StreamDevice-master/src/O.linux-x86_64"
make[1]: *** [/home/lytt/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: leave the directory "/home/lytt/epics/streamdevice/StreamDevice-master/src"
make: *** [/home/lytt/epics/base/configure/RULES_DIRS:85: src.install] Error 2
I have the following files in my include file:
asynCommonSyncIO.h          asynInterposeEos.h
asynDriver.h                asynInterposeFlush.h
asynDrvUser.h               asynOctet.h
asynEnum.h                  asynOctetSyncIO.h
asynEnumSyncIO.h            asynOption.h
asynEpicsUtils.h            asynOptionSyncIO.h
asynFloat32Array.h          asynParamType.h
asynFloat32ArraySyncIO.h    asynPortClient.h
asynFloat64Array.h          asynPortDriver.h
asynFloat64ArraySyncIO.h    asynRecord.h
asynFloat64.h               asynShellCommands.h
asynFloat64SyncIO.h         asynStandardInterfaces.h
asynGenericPointer.h        asynUInt32Digital.h
asynGenericPointerSyncIO.h  asynUInt32DigitalSyncIO.h
asynGpibDriver.h            devCommonGpib.h
asynInt16Array.h            devGpib.h
asynInt16ArraySyncIO.h      devSupportGpib.h
asynInt32Array.h            drvAsynIPPort.h
asynInt32ArraySyncIO.h      drvAsynIPServerPort.h
asynInt32.h                 drvAsynSerialPort.h
asynInt32SyncIO.h           epicsInterruptibleSyscall.h
asynInt64Array.h            paramErrors.h
asynInt64ArraySyncIO.h      ParamListInvalidIndex.h
asynInt64.h                 ParamListParamNotFound.h
asynInt64SyncIO.h           ParamValNotDefined.h
asynInt8Array.h             ParamValStringSizeRequestTooBig.h
asynInt8ArraySyncIO.h       ParamValValueNotChanged.h
asynInterposeCom.h          ParamValWrongType.h
I want to know, according to your first method, you can compile. Is the error reported because of missing files in my file? And will it affect me later when I use StreamDevice for work? Thank you!
------------------ 原始邮件 ------------------
发件人: "Mark Rivers" <[email protected]>;
发送时间: 2021年4月2日(星期五) 晚上9:38
收件人: "回忆回眸"<[email protected]>;
抄送: "EPICS Tech-Talk"<[email protected]>;
主题: RE: 回复: 回复: CentOS8--An error occurred when installing StreamDevice
Ø  The following error occurred in the first method:
Ø  Definition of SUPPORT conflicts with ASYN support.
Ø  In this application a RELEASE file defines
Ø  SUPPORT = /home/lytt/epics/streamdevice/StreamDevice-master/..
You must not have typed my first method correctly.  You will see that I commented out the line that defined SUPPORT, but clearly you have not done that.
Ø  The second method has the following error:
Ø  ../AsynDriverInterface.cc:41:10: Fatal error: asynDriver.h: No such file or directory
You will see that the include files do not include the asyn4-38/include directory, as in your original post.  I don’t see a typo in my second method, but perhaps I am missing it.  Or perhaps you have not actually built asyn successfully?
Please send the output of this command:
ls –l /home/lytt/epics/asyn4/asyn4-38/include
Ø  The third method has the following error:
Ø  SUPPORT = /home/lytt/epics/streamdevice/StreamDevice-master/../..
Ø  but ASYN at /home/lytt/epics/streamdevice/StreamDevice-master/../../asyn4/asyn4-38 defines
Ø  SUPPORT = /corvette/home/epics/devel
That means you have left the incorrect definition of SUPPORT in asyn4-38/configure/RELEASE.  corvette is my Linux server!  You need to either fix the definition of SUPPORT in that asyn file, or comment it out if it is not used.
Sent: Friday, April 2, 2021 8:18 AM
Subject:
According to your statement, I did the test separately.
make[2]: Enter the directory "/home/lytt/epics/streamdevice/StreamDevice-master/configure/O.linux-x86_64"
perl -CSD /home/lytt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
but ASYN at /home/lytt/epics/asyn4/asyn4-38 defines
make[2]: *** [/home/lytt/epics/base/configure/RULES_BUILD:188:checkRelease] Error 1
make[2]: leave the directory "/home/lytt/epics/streamdevice/StreamDevice-master/configure/O.linux-x86_64"
make[1]: leave the directory "/home/lytt/epics/streamdevice/StreamDevice-master/configure"
make: *** [/home/lytt/epics/base/configure/RULES_DIRS:85: configure.install] Error 2
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -DUSE_TYPED_RSET -DSTREAM_INTERNAL -O3 -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I.- I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/home/lytt/epics/base/include /compiler/gcc -I/home/lytt/epics/base/include/os/Linux -I/home/lytt/epics/base/include -MM -MF AsynDriverInterface.d ../AsynDriverInterface.cc
  #include "asynDriver.h"
Compilation is interrupted.
It seems that this problem is very difficult to solve. If you can provide a detailed installation tutorial on asyn, StreamDevice, I would be very grateful. The installation manual given on the official website is very simple, and no standardized installation directory is given during installation. So it's easy to have problems during installation, and don't know where the error occurred. If you can provide a catalog of specifications for installation, I would also appreciate it very much. Thank you!
发送时间: 2021年4月2日(星期五) 晚上7:49
主题: Re: 回复: CentOS8--An error occurred when installing StreamDevice
> According to what you said, what should my definition of SUPPORT look like?
> Is it defined to the epics directory?
Here are 3 options for fixing your RELEASE file.
The first does not use SUPPORT at all.
#SUPPORT=$(TOP)/..
ASYN=/home/lytt/epics/asyn4/asyn4-38
#CALC=/home/lytt/epics/calc/calc_R3-4/calc-3-4
PCRE=/home/lytt/epics/streamdevice/StreamDevice-master/prce/prce2-10.36
The second defines support as an absolute path:
SUPPORT=/home/lytt/epics
ASYN=$(SUPPORT)/asyn4/asyn4-38
#CALC=$(SUPPORT)/calc/calc_R3-4/calc-3-4
The third defines support as a relative path:
SUPPORT=$(TOP)/../..
Your original RELEASE file defined support as a relative path, but it was incorrect because it needed one more "/.." because you have a non-standard directory structure under /home/lytt/epics.  You also then had the paths relative to SUPPORT wrong, you did not want /home/lytt/epics after $(SUPPORT).
Sent: Friday, April 2, 2021 1:19 AM
To: Mark Rivers
Subject:
Sorry to reply to your message now! According to what you said, what should my definition of SUPPORT look like? Is it defined to the epics directory? My ASYN is an absolute path, and that asyn4-38 is a non-standard directory structure. I did it again with CentOS7, but there will still be such an error. Thank you!
发送时间: 2021年4月2日(星期五) 中午12:12
主题: Re: CentOS8--An error occurred when installing StreamDevice
It looks to me like your definition of SUPPORT as $(TOP)/.. is incorrect. That would not point to a directory above home/epics. I suggest you replace the definition of ASYN with its absolute path.
You have a non-standard directory structure where there is an additional asyn4 directory above the asyn4-38 directory.
Sent from my iPhone
On Apr 1, 2021, at 10:22 PM,
回忆回眸 <[email protected]> wrote:
This is the entire content of my RELEASE. Take a look, is there something wrong with the configuration? The installation path of ASYN is the installation path of my asyn. Thank you very much!
#RELEASE Location of external products
# Run "gnumake clean uninstall install" in the application
# top directory each time this file is changed.
# NOTE: The build does not check dependencies on files
# external to this application. Thus you should run
# "gnumake clean uninstall install" in the top directory
# each time EPICS_BASE, SNCSEQ, or any other external
# module defined in the RELEASE file is rebuilt.
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
# If you don't want to install into $(TOP) then
# define INSTALL_LOCATION_APP here
#INSTALL_LOCATION_APP=<fullpathname>
SUPPORT=$(TOP)/..
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
ASYN=$(SUPPORT)/home/lytt/epics/asyn4/asyn4-38
#CALC=$(SUPPORT)/home/lytt/epics/calc/calc_R3-4/calc-3-4
PCRE=$(SUPPORT)/home/lytt/epics/streamdevice/StreamDevice-master/prce/prce2-10.36
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=/home/lytt/epics/base
# These lines allow developers to override these RELEASE settings
# without having to modify this file directly.
-include $(TOP)/../RELEASE.local
-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
-include $(TOP)/configure/RELEASE.local
发送时间: 2021年4月2日(星期五) 中午11:09
Please show the contents of the stream/configure/RELEASE file.
There is no need to reinstall asyn.
Sent from my iPhone
On Apr 1, 2021, at 9:15 PM,
Thanks for your reply! Excuse me, according to what you said, there is a problem with my RELEASE, how should I solve it? Do I want to reinstall the latest version of asyn? Or reconfigure RELEASE? Thank you!
发送时间: 2021年4月2日(星期五) 凌晨0:54
主题: RE: CentOS8--An error occurred when installing StreamDevice
I forgot to include tech-talk in my original reply.
> Among them “asyn” has been installed and the asyn installation path is configured in configure/RELEASE.
It really seems like there is a problem with your configure/RELEASE file.  If asyn were defined there then it should be in the list of include paths.  I have broken the output of your compile command so each -I starts on a new line to make it easier to read.
-I.
-I../O.Common
-I.
-I.
-I..
-I../../include
Note that it is not searching the asyn directory.
This is what I get when I compile on Centos8:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -DUSE_TYPED_RSET -DSTREAM_INTERNAL   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common
-I.
-I.
-I..
-I../../include
-I/corvette/home/epics/devel/asyn-4-41/include
-I/corvette/home/epics/devel/calc-3-7-3/include
-I/corvette/usr/local/epics-devel/base-7.0.5/include/compiler/gcc
-I/corvette/usr/local/epics-devel/base-7.0.5/include/os/Linux
-c ../AsynDriverInterface.cc
Note that it is searching in asyn-4-41.
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of
回忆回眸 via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Thursday, April 1, 2021 1:50 AM
To: tech-talk
Subject: CentOS8--An error occurred when installing StreamDevice
Hello, I got the following error when installing StreamDevice:
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -DUSE_TYPED_RSET -DSTREAM_INTERNAL -O3 -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I.- I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/home/lytt/epics/base/include /compiler/gcc -I/home/lytt/epics/base/include/os/Linux -I/home/lytt/epics/base/include -c ../AsynDriverInterface.cc
    Among them “asyn” has been installed and the asyn installation path is configured in configure/RELEASE. How can I solve this? Thank you!
RE: 回复: 回复: CentOS8--An error occurred when installing StreamDevice Mark Rivers via Tech-talk
Prev: RE: 回复: 回复: CentOS8--An error occurred when installing StreamDevice Mark Rivers via Tech-talk
Next: phoebus LED in boolean button Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
