1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64.
From: Noboru Yamamoto via Tech-talk <[email protected]>
To: Till Straumann via Tech-talk <[email protected]>
Date: Tue, 6 Apr 2021 13:03:43 +0900
Hi, friends in EPICS community.
Recently I got Apple Macbook pro with Apple M1 CPU, running macOS Big Sur.
Today, I successfully built fat binaries for EPICS R7 base software.
So far I tested softIOC and ca_get command in both x86_64 and arm64 architectures
using clang/clang++ compilers from Apple.
To build these binraries, I just needed to modify Makefiles as shown below.
1) In base/configure/os/CONFIG_SITE.Common.darwin-x86, set the ARCH_CLASS variable as
	ARCH_CLASS = x86_64 arm64
2) Rebuild "libreadline.dylib" in /usr/local/lib ( or where you installed it) as a fat binary.
To build it,  I modified  readline-8.1/Makefile:
CFLAGS = -arch x86_64 -arch arm64 -g -O2 -Wno-parentheses -Wno-format-security
and readline-8.1/shlib/Makefile:
SHOBJ_LDFLAGS = -arch x86_64 -arch arm64 -dynamiclib -dynamic -undefined dynamic_lookup
Noboru Yamamoto
J-PARC accelerator control group
KEK, JAPAN
Noboru Yamamoto
Accelerator Control group
J-PARC center/KEK & JAEA
web: http://www-acc.kek.jp/EPICS_Gr/default.html
Re: compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64. Johnson, Andrew N. via Tech-talk
Prev: Re: Documentation to program CSS Phoebus scripts using JS and Python Johnson, Andrew N. via Tech-talk
Next: Re: Thermo Radiation Detectors FHT 6020 Smith, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Thermo Radiation Detectors FHT 6020 Smith, Martin via Tech-talk
Next: Re: compiling EPICS R7 base on macOS Big Sur as fat binaries for x86_64 and arm64. Johnson, Andrew N. via Tech-talk
