1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: phoebus LED in boolean button
From: Pierrick M Hanlet via Tech-talk <[email protected]>
To: "Manoussakis, Adamandios" <[email protected]>
Date: Tue, 6 Apr 2021 14:05:26 +0000
Thank you Adamandios,
Presently, I'm doing exactly as you suggest, which is to have a separate LED connected to the read (bi) record and
the button controlled by the bo record.  But what I'd prefer is to dispose of the 2nd LED and simply use the LED in
the boolean button to indicate the read record's value.
Cheers,
Pierrick
On 4/5/21 7:29 PM, Manoussakis, Adamandios wrote:
PNG image
RE: phoebus LED in boolean button Manoussakis, Adamandios via Tech-talk
phoebus LED in boolean button Pierrick M Hanlet via Tech-talk
Prev: Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Mark Rivers via Tech-talk
Next: Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: phoebus LED in boolean button Manoussakis, Adamandios via Tech-talk
Next: RE: phoebus LED in boolean button Manoussakis, Adamandios via Tech-talk
