1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: MDEL Field
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Alfio Rizzo <[email protected]>
Date: Tue, 6 Apr 2021 22:06:30 -0700
On 4/6/21 12:01 PM, Alfio Rizzo via Tech-talk wrote:
> Hi
> I would like to have some clarification about the MDEL field.
> If I understood correctly from the online documentation,
> If I set a value > 0 , the PV monitor (camonitor or pvmonitor)
> should be triggered if and only if
> ABS(ValPrev - ValCurr) > MDEL
> where ValPrev and ValCurr is the previous and current value of my PV.
> So, I have made some simualtion, but apparently the monitor is triggered also when the condition before is not satisfied.
> Do I miss something ?
In addition to the value change event (DBE_VALUE), most clients also subscribe
to the alarm change event (DBE_ALARM).  So eg. a 'camonitor' will by default show
an update if either the MDEL deadband is exceeded, or if the alarm state changes.
You can use the '-m' argument of camonitor to probe this.  See 'caget -h' for other
options.
> $ camonitor PiraniGauge_RB
> PiraniGauge_RB                 2021-04-06 21:50:55.628735 0.0398545 HIHI MAJOR
> PiraniGauge_RB                 2021-04-06 21:51:04.628750 0.0374571 HIGH MINOR
> PiraniGauge_RB                 2021-04-06 21:51:08.628789 0.0342738
> PiraniGauge_RB                 2021-04-06 21:51:18.628817 0.0247016 LOW MINOR
> PiraniGauge_RB                 2021-04-06 21:51:22.628811 0.0218172 LOLO MAJOR
> PiraniGauge_RB                 2021-04-06 21:51:35.628792 0.0222724 LOW MINOR
> PiraniGauge_RB                 2021-04-06 21:51:39.628829 0.025354
> PiraniGauge_RB                 2021-04-06 21:51:50.628785 0.0357844 HIGH MINOR
> PiraniGauge_RB                 2021-04-06 21:51:54.628773 0.0385044 HIHI MAJOR
> PiraniGauge_RB                 2021-04-06 21:52:06.628815 0.0379849 HIGH MINOR
> PiraniGauge_RB                 2021-04-06 21:52:11.628786 0.0341212
> PiraniGauge_RB                 2021-04-06 21:52:21.628730 0.0245598 LOW MINOR
> PiraniGauge_RB                 2021-04-06 21:52:25.628775 0.0217217 LOLO MAJOR
> PiraniGauge_RB                 2021-04-06 21:52:38.628715 0.0223802 LOW MINOR
> PiraniGauge_RB                 2021-04-06 21:52:42.628800 0.0255035
> PiraniGauge_RB                 2021-04-06 21:52:52.628759 0.0350866 HIGH MINOR
> PiraniGauge_RB                 2021-04-06 21:52:56.628754 0.0380378 HIHI MAJOR
Subscribe only to DBE_VALUE.
> $ camonitor -m v PiraniGauge_RB
> PiraniGauge_RB                 2021-04-06 21:57:28.828710 0.039463 HIHI MAJOR
cf. record support code for ai where the monitor event for .VAL originates.
https://github.com/epics-base/epics-base/blob/348d1bba176117178eb2c59cd0be193e1cf104ca/modules/database/src/std/rec/aiRecord.c#L461
recGblResetAlarms() handles alarm change
https://github.com/epics-base/epics-base/blob/348d1bba176117178eb2c59cd0be193e1cf104ca/modules/database/src/ioc/db/recGbl.c#L208
recGblCheckDeadband() handles floating point deadband
https://github.com/epics-base/epics-base/blob/348d1bba176117178eb2c59cd0be193e1cf104ca/modules/database/src/ioc/db/recGbl.c#L354
Re: MDEL Field Alfio Rizzo via Tech-talk
Prev: Re: phoebus LED in boolean button Pierrick M Hanlet via Tech-talk
Next: Re: MDEL Field Alfio Rizzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: MDEL Field Alfio Rizzo via Tech-talk
