1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: StreamDevice mbbi format-converter problem
To: "Mooney, Tim M." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 8 Apr 2021 16:55:21 +0000
Hi Tim,
Quick search “%%” on https://paulscherrerinstitute.github.io/StreamDevice/formats.html , “%%” or “\%” should have worked.
Nonetheless, give a try on this (basically use \? for enum value 2):
get_units { out "REMOTE; CHAN \$1; UNITS?";  in "%{cm|in|\?}"; }
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: "Mooney, Tim M." <[email protected]>
Date: Thursday, April 8, 2021 at 11:52 AM
Subject: StreamDevice mbbi format-converter problem
Dear folks,
I have an mbbi record with streamDevice support, and the following protocol:
get_units { out "REMOTE; CHAN \$1; UNITS?";  in "%{cm|in|%%}"; }
Here is the record definition:
record(mbbi, "$(device):UNITS")
    field(DESC, "Units")
    field(DTYP, "stream")
    field(INP,  "@cryomagLM510.proto get_units($(chan)) $(port)")
    field(ZRST, "cm")
    field(ONST, "in")
    field(TWST, "%")
    field(SCAN, "Passive")
When the device response is "cm" or "in" it is handled correctly, but when the response is "%" the record value doesn't change, even though the asyn trace output shows that the character received actually was "%"
2021/04/08 10:03:28.517 164.54.115.98:4266 write 23
REMOTE; CHAN 1; UNITS?
2021/04/08 10:03:28.617 164.54.115.98:4266 read 3
(Three characters are received because the input terminator is "interminator  = CR LF;")
Originally, I had the protocol wrong because I didn't realize the "%" would be treated as a format converter:
get_units { out "REMOTE; CHAN \$1; UNITS?";  in "%{cm|in|%}"; }
But then I tried changing the protocol file to this:
get_units { out "REMOTE; CHAN \$1; UNITS?";  in "%{cm|in|\%}"; }
followed by streamReload(), which didn't work, and finally to this:
followed by streamReload(), which also didn't work.
I'm using StreamDevice-2-8-9.  I can't figure out what I'm doing wrong.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Re: StreamDevice mbbi format-converter problem Mooney, Tim M. via Tech-talk
Prev: Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Maren Purves via Tech-talk
Next: Re: StreamDevice mbbi format-converter problem Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: StreamDevice mbbi format-converter problem Mooney, Tim M. via Tech-talk
