1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: line scan camera with ADAravis driver skips frames
From: Katie Matusik via Tech-talk <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 8 Apr 2021 15:24:06 -0700
Hi Mark et al.,
I updated to the latest Aravis release and master ADAravis driver. I also changed my net.core.rmem_default and net.core.rmem_max  to 8 MB each. The biggest difference I saw was getting rid of the virtualization layer and installing EPICS locally. I'm not sure why Docker has such an impact on the network bandwidth considering that I am using the host network, but removing it now allows me to get to higher frame rates without missing frames. Now I also have the camera directly plugged into an ethernet card that should be able to handle 1000 Mb/s on each port, and I configure the port such that it should only see the traffic from this one Basler camera. This camera model should be capable of 8 kHz, but instead I get maybe half that frame rate with both the Basler Pylon software as well as the IOC. We plan to update the network card to handle 10 Gb and I will let you know if that fixes this problem, since now this seems like a bandwidth issue. My only other question comes from grabbing my BASLER1:image1:ArrayData PV; I have my EPICS_CA_MAX_ARRAY_BYTES set to 150,000,000 (very large for testing) on both the host as well as inside the IOC (verified with epicsEnvShow). When I caget BASLER1:image1:ArrayData, it outputs the following error, "BASLER1:image1:ArrayData *** CA error The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES". I can return the array using caget up to  ~8100 elements, after which I receive the above error. Using pyepics, I can output the full array. Thanks so much in advance and please let me know what further info you need.
Best,
Katie
On Tue, Apr 6, 2021 at 11:46 AM Mark Rivers <[email protected]> wrote:
Hi Katie,
Ø  I am using the latest areaDetector-master with ADAravis R1-3 and ADGenICam-master.
The fact that you are using ADAravis R1-3 means you are using an old aravis 0_7 release.  It could be that the problem you are seeing has already been fixed in aravis.
I suggest updating to the latest aravis 0_8 release and ADAravis R2-2 or master.
From: Tech-talk <[email protected]> On Behalf Of Katie Matusik via Tech-talk
Sent: Tuesday, April 6, 2021 1:07 PM
To: tech-talk <[email protected]>
Subject: line scan camera with ADAravis driver skips frames
Hi everyone,
The camera that I am connecting to via GigE is a Basler Racer line scan camera (12288 x 1 px) model raL12288-8gm. When I run the camera with binning 1x1 and 8-bit pixel format at 1kHz (slowest frame rate), the driver keeps up until about 30K frames, at which point I start accumulating frame failures and underruns. With a higher frame rate, it happens almost immediately.
I am using the latest areaDetector-master with ADAravis R1-3 and ADGenICam-master. I am running this IOC in a Docker using the host network which has MTU set to 9000. I made a slight adjustment to the ADAravis.cpp driver regarding setting the packet size to jumbo packets rather than determining optimum packet size, which was interfering with my network (lines 379-381 in ADAravis.cpp):
377     if (ARV_IS_GV_DEVICE(this->device)) {
378         // Automatically determine optimum packet size
379 //        arv_gv_device_auto_packet_size(ARV_GV_DEVICE(this->device));
380         // Uncomment this line to set jumbo packets
381         arv_gv_device_set_packet_size(ARV_GV_DEVICE(this->device), 9000);
382     }
I'm attaching snapshots of my camera features settings as well as my st.cmd and st.cmd.base files. Please let me know what other information you need. When I run this using the Basler pylonViewer software, I do not see these skipped frames.
Best,
Katie
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Katie Matusik
Systems Engineer
5750 Imhoff Drive, Suite I
Concord, CA 94520 USA
Office: 1 (925) 326 - 7926
RE: line scan camera with ADAravis driver skips frames Mark Rivers via Tech-talk
line scan camera with ADAravis driver skips frames Katie Matusik via Tech-talk
Prev: Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Maren Purves via Tech-talk
Next: RE: line scan camera with ADAravis driver skips frames Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: line scan camera with ADAravis driver skips frames Mark Rivers via Tech-talk
