1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Array widget in Display Builder
From: Tomasz Brys via Tech-talk <[email protected]>
Date: Wed, 14 Apr 2021 12:27:14 +0000
I need help to understand an Array widget.
I created an array widget with five TextEntries. I set PV as loc://myarray<VDoubleArray>. When I try to write something to the Array I got an error.
When I set PV as loc://myarray<VDoubleArray>(0) the value 0 appears in my Array and I can write whatever I want. Even if I write more elements than five.
But e.g if I write [1,2,3,4,5] it is OK, then I write[11,22,33] I will see [11,22,33,4,5]. It looks like the array widget ignore the size of array which I want to write.
Is it a bug or special feature? If this is a feature how I can remove remaining [4,5]. Can anyone explain? Maybe I am using the widget wrong?
Cheers
Tomasz Brys
Re: Array widget in Display Builder Kasemir, Kay via Tech-talk
Prev: Re: External: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Next: CSS Display builder web runtime. Vishnu Patel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: problems with running EPICS Gateway on virtual machines? Ben Franksen via Tech-talk
Next: Re: Array widget in Display Builder Kasemir, Kay via Tech-talk
