1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CSS Display builder web runtime.
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>, Vishnu Patel <[email protected]>
Date: Wed, 14 Apr 2021 13:19:11 +0000
> java.net.MalformedURLException: no protocol: /var/lib/tomcat9/webapps/dbwr/LCPC/ColdBox.bob
Looks like you tried to access
    https://your.server/dbwr/view.jsp?display=/var/lib/tomcat9/webapps/dbwr/LCPC/ColdBox.bob
The display link needs to be a valid URL, for example this to access a file on the server:
   https://your.server/dbwr/view.jsp?display=file://var/lib/tomcat9/webapps/dbwr/LCPC/ColdBox.bob
But you might want to block generic file access for security reasons on either the tomcat level and/or by defining WHITELIST* settings.
So better serve the display files from your web as well and then use
   https://your.server/dbwr/view.jsp?display=http://your.server/displays/LCPC/ColdBox.bob
Search the web for setting up Apache httpd and tomcat so that httpd is used for serving plain files (like .../displays) and redirecting dedicated URLs to tomcat (like dbwr/*).
-Kay
From: Tech-talk <[email protected]> on behalf of Vishnu Patel via Tech-talk <[email protected]>
Sent: Wednesday, April 14, 2021 9:07 AM
Subject: [EXTERNAL] CSS Display builder web runtime.
Hello,
      I am using display builder web runtime with tomcat9 and java 14.
The below error has been encountered.
HTTP Status 500 – Internal Server Error
Type Exception Report
Message Servlet execution threw an exception
Description The server encountered an unexpected condition that prevented it from fulfilling the request.
Exception
javax.servlet.ServletException: Servlet execution threw an exception
	org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
Root Cause
java.lang.Error: Cannot create display /var/lib/tomcat9/webapps/dbwr/LCPC/ColdBox.bob {}
	dbwr.servlets.ScreenServlet.createHtml(ScreenServlet.java:60)
	dbwr.servlets.DisplayCache.lambda$getOrCreate$0(DisplayCache.java:32)
	java.base/java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1708)
	dbwr.servlets.DisplayCache.getOrCreate(DisplayCache.java:32)
	dbwr.servlets.ScreenServlet.doGet(ScreenServlet.java:109)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:634)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
Root Cause
	java.base/java.net.URL.<init>(URL.java:672)
	java.base/java.net.URL.<init>(URL.java:568)
	java.base/java.net.URL.<init>(URL.java:515)
	dbwr.parser.Resolver.<init>(Resolver.java:65)
	dbwr.servlets.ScreenServlet.createHtml(ScreenServlet.java:48)
Thanks
Vishnu
CSS Display builder web runtime. Vishnu Patel via Tech-talk
Prev: CSS Display builder web runtime. Vishnu Patel via Tech-talk
Next: Re: Array widget in Display Builder Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: EPICS-Support for Amtek / Gamry potentiostat Sintschuk, Michael via Tech-talk
