1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Python Script call from Button press, module not found
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 16 Apr 2021 21:25:48 +0000
Thanks everyone for your input!
Thanks for the suggestion Kay, ill have to look into PCASPY some more but would this be similar to using pyepics as an interface to CA?  Right now it looks like either move it to an IOC (pythonIoc), translate it over to C (regular IOC), or throw some pyepics in the python script and have it run an event loop looking for a PV change.
From: Tech-talk <[email protected]> On Behalf Of Kasemir, Kay via Tech-talk
Sent: Friday, April 16, 2021 10:52 AM
To: [email protected]
Subject: Re: Python Script call from Button press, module not found
Hi:
If the goal is that writing to a PV triggers something in python, wouldn't it be more straight forward to have a python-based CA server?
It serves the "DoIt" PV, and writing to that PV makes the python code do something.
PCASPY, https://pcaspy.readthedocs.io/en/latest/, allows you to implement just that, without need to first create some 'mailbox' IOC for serving the value, then having a script poll/monitor that PV for changes.
With PCASPY you can also support put-callback, so clients writing to the PV can not only trigger whatever you want to happen, but they can also get notified when the action completes.
-Kay
Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
Re: Python Script call from Button press, module not found Kasemir, Kay via Tech-talk
RE: Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
Re: Python Script call from Button press, module not found Matt Newville via Tech-talk
Re: Python Script call from Button press, module not found Johnson, Andrew N. via Tech-talk
Re: Python Script call from Button press, module not found Ben Franksen via Tech-talk
RE: Python Script call from Button press, module not found Layne (US), William C via Tech-talk
Prev: Re: WIN_32 Marty Kraimer via Tech-talk
Next: RE: WIN_32 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Python Script call from Button press, module not found Kasemir, Kay via Tech-talk
Next: Re: Python Script call from Button press, module not found Matt Newville via Tech-talk
