1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: problems with running EPICS Gateway on virtual machines?
From: Ru Igarashi via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sat, 17 Apr 2021 06:22:12 +0000
From: Michael Davidsaver <[email protected]>, Thursday, April 15, 2021 14:47
>On 4/13/21 11:29 PM, Ru Igarashi via Tech-talk wrote:
>> [normally, I'd inline my response but I'm stuck with Web Outlook.  My apologies.]
> Hello Andrew,
>> re: camonitor: the errant sequence is the same with and without camonitor
>> running in parallel.  My thinking was that the reliance on the Channel
>> Access monitors meant that update occasionally necessarily would
>> eventually be out of sync. ...
> I don't think anyone else addressed this point specifically,
> and I think it is an important point to make.  CA (and PVA)
> subscriptions should always, eventually, be "in-sync". This is an
> essential property for a robust distributed control system to have!
Subscriptions and even caget(), so far, are not impacted with the
observed problem, and, up until I ran my tests on one very specific
configuration, asynchronous caput() weren't affected (at least to
nowhere near this extent).  Then I ran on this one very specific
configuration and observed a huge uptick in failed updates in
asynchronous caputs.  I think I've simply run across an odd
combination of processor, OS and EPICS versions.  I'm just trying
to determine what I need to change to make it work.
> If a PV produces a burst of updates which exceeds some internal
> buffers, the most recent update will never be discarded.  So all
> clients will eventually receive the most recent update produced.
I'm seeing that even when the asynchronous caput fail to update
properly: immediate caget after put are updating properly.  I have
yet to run my tests on camonitors.  That is, EPICS is not failing in
that regard, either.
ru
problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Re: problems with running EPICS Gateway on virtual machines? Hugo Slepicka via Tech-talk
Re: External: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Re: External: Re: problems with running EPICS Gateway on virtual machines? Johnson, Andrew N. via Tech-talk
Re: problems with running EPICS Gateway on virtual machines? Michael Davidsaver via Tech-talk
Prev: Re: Fanout and asub interaction issues Wang, Andrew via Tech-talk
Next: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: problems with running EPICS Gateway on virtual machines? Michael Davidsaver via Tech-talk
Next: Re: External: Re: problems with running EPICS Gateway on virtual machines? Ralph Lange via Tech-talk
