Hi Yong,
On 4/19/21 6:43 AM, Hu, Yong wrote:
> “127.255.255.255” is not the right broadcast. Assuming you are using Linux, the output of /sbin/ifconfig does NOT have “127.255.255.255” as broadcast for the interface “lo”.
fyi. the (implicit) loopback broadcast address is a semi-documented Linux specific behavior.
It is doesn't need to be explicitly configured, it is always active.
Using 127.255.255.255 for searching works great with the CA implementations I've tested,
also my new PVXS implementation of PVA. I've found this "trick" handy for local testing.
However, it doesn't work with the pvAccessCPP implementation of PVA due to a quirk which is
related to Klemen's recent problem with global broadcasts.
- pv Access setup Дмитрий Прощенко via Tech-talk
- Re: pv Access setup Michael Davidsaver via Tech-talk
- Re: pv Access setup Дмитрий Прощенко via Tech-talk
- Re: pv Access setup Hu, Yong via Tech-talk
Re: pv Access setup montis via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
