1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution?
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: Oscar Ibañez <oscar.ibanez.spain.1980 at gmail.com>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 21 Apr 2021 20:45:44 +0000
Hi Óscar,
On Apr 21, 2021, at 3:12 PM, Oscar Ibañez via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Yest, that's right. Permissions to write PVs. But logging out & in, or using 'sudo' are not acceptable solutions for this situation. Any solution has to come from the Phoebus graphical interface. No command line. The computer session has to remain untouched.
Neither Pheobus nor any other EPICS GUI that I know of may be suitable for your requirements as you describe them. The Channel Access protocol may also be unsuitable if you expect the IOC to continue to enforce the access rules as it does at the moment.
The existing EPICS Access Security design only allows each virtual circuit (i.e. the client - server connection which is used to transport PV data between those two end-points) to have a single user identity associated with it, and that identity is the name of the account running the software on the client. Thus all EPICS CA clients and GUIs have only ever supported a single user.
With enough changes it would be possible for a single process to open parallel connections to a single IOC that have different user identities, but that would involve making API changes to the client library which existing EPICS clients wouldn’t support. Modifications to add that support throughout the software stack would probably take quite a few FTEs of skilled programmer effort to implement.
- Andrew
> El 21/04/2021 a las 21:49, Kasemir, Kay escribió:
>>> We are going to have several users using Phoebus. Different users have
>>> different permissions to view and to edit, like any other system.
>>> the change has to be made without logging out from the current computer session.
>> Permissions to do _what_​?
>> Write PVs?
>> That's handled by Channel Access (or PV Access) security, which is based on the current user.
>> Phoebus (or EDM, MEDM, python CA library, command line caput, ...) don't have any way to change that user.
>> The only option you have is either log out & log back in,
>> or use 'sudo' to change user and start another instance of the program as that different user.
>> -Kay
Complexity comes for free, simplicity you have to work for.
What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
Re: What is the best (and simple) way to implement security in a Phoebus solution? J. Lewis Muir via Tech-talk
Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
Prev: Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
Next: Re: What is the best (and simple) way to implement security in a Phoebus solution? J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Next: Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
ANJ, 21 Apr 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
