1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: RPM packages for EPICS
From: "Hu, Yong via Tech-talk" <tech-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 22 Apr 2021 13:58:04 +0000
Thanks, Ralph. That is really good advice!
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Reply-To: Ralph Lange <ralph.lange at gmx.de>
Date: Thursday, April 22, 2021 at 5:18 AM
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
On Wed, 21 Apr 2021 at 16:43, Hu, Yong via Tech-talk <tech-talk at aps.anl.gov> wrote:
Has any facility built, smoothly deployed and happily used RPM packages for EPICS installation of the base and popular support modules (seq, asyn, motor, streamDevice, etc.)? Please share your repositories (or building rules / specs) and your experience. Thank you!
My 2cts...
The Debian packaging is "near distribution quality": following all applicable guidelines and file system standards, including all necessary legal and license information. The packages would need few changes (if any) to be accepted in the Debian distribution.
While the packaging tools are different, Fedora / Red Hat guidelines and rules are very similar.
I think it would be best to keep a Red Hat packaging effort as close as possible to the Debian packaging, using the same names, versions, places, techniques. With the Debian packaging and its helper tools as a reference, the way towards a similar Red Hat packaging should be straightforward. Long term, it would make it easier to apply fixes for problems found on one distribution to the other, improve user experience (packaged EPICS works the same on Debian and RedHat) and hopefully create a larger group of packaging contributors, which could/should reduce the amount of work for each person. A lot of EPICS places use Red Hat, so I am sure there are others who would help.
My suggestion would be to start working on Red Hat packaging within the epicsdeb project on GitHub that collects the existing Debian packaging. (If the "deb" part of the name becomes an issue, we could rename it at some point.)
Create a workflow / branching model that allows for both packaging efforts to use the same sources and add their specifics without affecting the other.
Cheers,
~Ralph
RPM packages for EPICS Hu, Yong via Tech-talk
Re: RPM packages for EPICS Ralph Lange via Tech-talk
Prev: Re: RPM packages for EPICS Ralph Lange via Tech-talk
Next: Re: Matlab 2020b crashes with labCA 3.7.2 Till Straumann via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Next: Re: RPM packages for EPICS J. Lewis Muir via Tech-talk
ANJ, 22 Apr 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
