Thank you! Yes, I couldn't get 3.15 to compile in the MDSplus Alpine container but 7.0.5 does, using your Dockerfile.
My reasons for trying 3.15.6 was because another project we're looking at is the React Automation Studio produced by William Duckitt at iThemba Lab in South Africa (Cape Town). They have a very interesting project that containerizes the different elements of a control system for their beamline work. Super neat project if you ask me. In discussions with him, he said Base 7 has been used in RAS builds with no major issues so we shall see.
Building the mdsexpr record support is not exactly clear on the MDSplus site so off to their mailing list for help! Thanks for the help with this!
Josh
Hi Josh,
I tried to build epics base in an alpine container awhile back for CI, and forget a lot of the details, but do have a working example I can share. I can't exactly remember what things were needed to fix what errors though.
FROM alpine:latest
RUN apk add --update make gcc git python3 py3-pip curl perl-dev readline-dev ncurses-dev build-base p7zip g++ RUN apk add --update libstdc++ linux-headers libexecinfo-dev libtirpc rpcgen
RUN git clone https://github.com/epics-base/epics-base.git WORKDIR /epics-base RUN echo "USR_CXXFLAGS+=-DIPPORT_USERRESERVED=5000 -fPIC -D__UCLIBC_MAJOR__=0" > configure/CONFIG_SITE.local RUN make
I do remember this tech talk gave some guidance: https://epics.anl.gov/core-talk/2020/msg01246.php and adding this to configure/CONFIG_SITE.local seemed to be needed: USR_CXXFLAGS+=-DIPPORT_USERRESERVED=5000 -fPIC -D__UCLIBC_MAJOR__=0. Also seem to remember running into more issues while building modules.
Best, Tynan
Hi Josh,
Welcome to the EPICS community!
On Apr 20, 2021, at 6:07 PM, Josh Fiddler via Tech-talk <tech-talk at aps.anl.gov> wrote:
> I have what seems to be a unique problem.
Apparently, but it should be easily solvable...
> To build the MDSplus EPICS interface requirements I appear to need the MDSplus libraries. MDSplus provides a docker image based on Alpine linux. I've added the required build tools with `apk`.
I don’t know of anyone using Alpine Linux with EPICS yet, but we're a pretty big community now.
> Everything goes swimmingly, so far as I can tell, until it comes to `src/libCom/osi` and then the compiler complains and quits. Here's the error
> ############# Begin Error snippet #############
> usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -c ../../../src/libCom/env/envSubr.c
> ../../../src/libCom/env/envSubr.c: In function 'envGetInetPortConfigParam':
> ../../../src/libCom/env/envSubr.c:411:21: error: 'IPPORT_USERRESERVED' undeclared (first use in this function)
> if (epicsParam<=IPPORT_USERRESERVED || epicsParam>USHRT_MAX) {
> ../../../src/libCom/env/envSubr.c:411:21: note: each undeclared identifier is reported only once for each function it appears in
> make[3]: *** [../../../configure/RULES_BUILD:232: envSubr.o] Error 1
> make[3]: Leaving directory '/epics/base-3.15.6/src/libCom/O.linux-x86_64'
> make[2]: *** [../../configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
> make[2]: Leaving directory '/epics/base-3.15.6/src/libCom'
> make[1]: *** [../configure/RULES_DIRS:84: libCom.install] Error 2
> make[1]: Leaving directory '/epics/base-3.15.6/src'
> ############# END ERROR SNIPPET #############
> The Asks:
> 1) Is there anyone who has some insights into this error or has built in Alpine?
The macro IPPORT_USERRESERVED is defined in /usr/include/netinet/in.h in my Linux (RHEL-7) system so my guess is that you need some networking -devel or similar package to be installed that provides that header or an equivalent. It’s definitely a standard networking constant so you just have to work out how to get hold of the right headers.
Our build documentation is somewhat out of date. If you want to test your build after it’s done, run ‘make runtests’ and it will execute the built-in test programs and report the results – always a good thing to do after building on a new OS-type.
Good luck!
- Andrew
Complexity comes for free, simplicity you have to work for.
- EPICS in Docker image Build Error base-3.15.6 (alpine linux) Josh Fiddler via Tech-talk
- Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Johnson, Andrew N. via Tech-talk
- Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Tynan Ford via Tech-talk
Re: RPM packages for EPICS J. Lewis Muir via Tech-talk
Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Josh Fiddler via Tech-talk
<2021>
2025
Re: EPICS in Docker image Build Error base-3.15.6 (alpine linux) Ralph Lange via Tech-talk
<2021>
2025
ANJ, 22 Apr 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
