1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: how to install alh on raspberry pi 4
From: Huyn Woo Ryu via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 27 Apr 2021 18:51:46 +0900
I installed base-3.15.8 successfully on raspberry pi
But when I install 'alh1_2_35' on raspberry pi OS(kernel version 5.10) on raspberry pi 4, it can't make successfully, the err as follows:
/usr/bin/ld: /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a(CrGlCur.o): undefined reference to symbol 'dlopen@@GLIBC_2.4'
/usr/bin/ld: //lib/arm-linux-gnueabihf/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [../../../../base/configure/RULES_BUILD:204: alh] Error 1
make[1]: Leaving directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm'
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2   I don't know how to fix it, could you give me some advice on it?
Please, Help me! I consumed many time for this problem.
Ryu
Re: how to install alh on raspberry pi 4 Mark Rivers via Tech-talk
Prev: Re: List all available PVs Stainer Tom via Tech-talk
Next: RE: RPM packages for EPICS Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: RTEMS BSP for MVME8100 Joel Sherrill via Tech-talk
Next: Re: how to install alh on raspberry pi 4 Mark Rivers via Tech-talk
ANJ, 27 Apr 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
