1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: List all available PVs
From: "Hu, Yong via Tech-talk" <tech-talk at aps.anl.gov>
To: Stainer Tom <Tom.Stainer at sckcen.be>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 27 Apr 2021 16:35:15 +0000
Our machine, NSLS-II, has been in Shutdown mode since the end of March and it is going to start up soon.
We are doing system checkup, preparing for the machine startup. We just found some disconnected PVs on our CS-Studio screens this morning. I am scratching my head to find out which IOC hosts them. We used to use the simple approach "dbl >pv.list" as Kay mentioned. I did a grep, nothing found. Probably I or someone else forgot to put "dbl >pv.list" at the end of that IOC's st.cmd. We are in the process of using Michael's "RecSync" in our IOCs, most of them are 5-year-old or more older. Probably because I or someone else forgot to add the support module "reccaster" to that IOC, I did a search in CS-Studio Channel Viewer, nothing found again. Now I am totally dumb __
Cheers,
Yong
On 4/27/21, 11:30 AM, "Tech-talk on behalf of Stainer Tom via Tech-talk" <tech-talk-bounces at aps.anl.gov on behalf of tech-talk at aps.anl.gov> wrote:
    Thank you Kay and Michael for the help and advice. I had come across Channel Finder & recsync previously but I wasn't quite sure how it worked and what it did exactly (I was also unsure if it supported PVA, given the name).
    Your responses have been very helpful.
    I will look into the documentation and try it out.
    Kind regards,
    Tom
        Hi:
        > If I may continue with your analogy and the case of the web, then in this context there are web crawlers that exist for the sole purpose to index web sites and to see what is out there on the web (whether advertised or not).
        > Similarly, I would like to know how one would go about making such a crawler for PVA, which could or could not be used in combination with a central registry.
        Right, I assume in the long run most sites come up with some way to catalog their PVs.
        One motivation: If a PV is online, you can use 'cainfo' to locate the associated IOC, then find the *.db file etc.
        But if a PV is simply disconnected, how do you figure out on what IOC it was supposed to be, so you can then debug the issue?
        Approaches can be as simple as adding "dbl >pv.list" to the end of the IOC startup script so you can later "grep" for record names.
        A tool that's used at several sites is the Channel Finder, https://urldefense.com/v3/__http://channelfinder.github.io__;!!P4SdNyxKAPE!U5AxcYQifhwM9SIxCOImHct1Ao4xTCbVFjD5UhA-EV67Io3JWdXh15RepiFb$ , which includes a "recsync" component via which IOCs publish all their record names.
        -Kay
List all available PVs Stainer Tom via Tech-talk
Re: List all available PVs Ralph Lange via Tech-talk
Re: List all available PVs Stainer Tom via Tech-talk
Re: List all available PVs Kasemir, Kay via Tech-talk
Prev: Re: List all available PVs Stainer Tom via Tech-talk
Next: Pointing an IOC to system-level lib files for build Katie Matusik via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Next: Re: List all available PVs Michael Davidsaver via Tech-talk
ANJ, 27 Apr 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
