1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: Larger build products in base-7.0.5
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 30 Apr 2021 11:20:49 -0500
Andrew,
Thanks for the info. You are correct; I don't see the '-g' option in the 7.0.4.1 build, but I do see the '-g' option in the 7.0.5 build.
Kevin
On 4/30/21 10:52 AM, Johnson, Andrew N. wrote:
You can double-check by comparing a gcc or g++ command in the two builds, in 7.0.4.1 you probably won’t see the -g option whereas in 7.0.5 I think you will. Please let us know if that’s not true.
Larger build products in base-7.0.5 Kevin Peterson via Tech-talk
Re: Larger build products in base-7.0.5 Johnson, Andrew N. via Tech-talk
Prev: Re: ADVimba disconnect Mark Rivers via Tech-talk
Next: EPICS 7 base on WSL2 Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: Larger build products in base-7.0.5 Johnson, Andrew N. via Tech-talk
ANJ, 30 Apr 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
