1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Means of comparing alarm status with a conditional in a CALC record
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Mooney, Tim M." <[email protected]>
Cc: "Wang, Andrew" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 12 May 2021 20:18:26 +0000
There are some additional values for the STAT field that can’t be transmitted over CA as an ENUM (the protocol only sends the first 16 state names as shown in Tim’s graphic from MEDM), but the calc record will get their numeric values. The full list of STAT values can be found in any of include/alarm.h, include/menuAlarmStat.h or dbd/menuAlarmStat.dbd in Base.
- Andrew
On May 12, 2021, at 2:56 PM, Mooney, Tim M. via Tech-talk <[email protected]> wrote:
Hi Andrew,
Yes, just specify the record's stat field in one of the calc record's input fields.  You'll get a number from the following list
<image.png>
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Wang, Andrew via Tech-talk <[email protected]>
Sent: Wednesday, May 12, 2021 2:36 PM
To: EPICS tech-talk <[email protected]>
Subject: Means of comparing alarm status with a conditional in a CALC record
All,
I was wondering if there was some method to compare the alarm severity, where I want to determine if one of my record’s STAT field is set to be NO_ALARM or COMM. Can that be done using something like a CALC record?
Andy
Complexity comes for free, simplicity you have to work for.
RE: Means of comparing alarm status with a conditional in a CALC record Wang, Andrew via Tech-talk
Re: Means of comparing alarm status with a conditional in a CALC record Mooney, Tim M. via Tech-talk
Prev: Re: Means of comparing alarm status with a conditional in a CALC record Mooney, Tim M. via Tech-talk
Next: [info] ICALEPCS 2021 abstract submission extended to May 20th Yingbing YAN via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: Means of comparing alarm status with a conditional in a CALC record Wang, Andrew via Tech-talk
