1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: caput output
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
Date: Thu, 13 May 2021 17:47:07 +0000
And I soon as I hit send, my email client revealed the window with:
https://epics.anl.gov/base/R3-15/7-docs/aiRecord.html
which seems to indicate that MDEL is intended only to keep the monitor from generating events less than this value.
     Greg
From: Tech-talk <[email protected]> On Behalf Of Leblanc, Gregory via Tech-talk
Sent: Thursday, May 13, 2021 1:44 PM
To: [email protected]
Subject: caput output
Hi folks!
I was working on the installation instructions to make them a bit more clear, and I ran across some caput behavior that I didn’t expect, but I’m not sure if that’s just because I’m not sure what to expect.  I looked at the CAref.html doc (https://epics.anl.gov/base/R3-15/7-docs/CAref.html#CommandTools) but this points to EPICS Base R3, and I didn’t know if there were any chances for R7.
Anyway, it looks to me like the MDEL field in my test.db only affects camonitor, and not caget.
Test.db:
record(ai, "temperature:water")
    field(DESC, "Water temperature in the fish tank")
    field(MDEL, "0.01")
Caput commands:
$ caput temperature:water 15.6
Old : temperature:water              15.5003
New : temperature:water              15.6
$ caput temperature:water 15.6001
Old : temperature:water              15.6
New : temperature:water              15.6001
$ caput temperature:water 15.61
Old : temperature:water              15.6001
New : temperature:water              15.61
$ caput temperature:water 15.62
Old : temperature:water              15.61
New : temperature:water              15.62
And from camonitor:
temperature:water              2021-05-13 13:36:04.090862 15.6
temperature:water              2021-05-13 13:36:14.587731 15.62
It looks like the MDEL only suppresses events (interrupts?  Not sure of the terminology used here) from changes smaller than MDEL and doesn’t actually suppress updates to the IOC.  I don’t know enough to tell if this is the intended behavior or not, and I’m quite confident that I didn’t get all the terminology correct.
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
caput output Leblanc, Gregory via Tech-talk
Prev: caput output Leblanc, Gregory via Tech-talk
Next: Re: Is there any "Getting started" or HOWTO for EPICS 7? Marty Kraimer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Basler acA2040-180kmnir camera description file Claus, Ric via Tech-talk
