1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Subject: RE: Archiver Appliance mgmt tomcat issue
From: "Manoussakis, Adamandios via Tech-talk" <tech-talk at aps.anl.gov>
To: Han Lee <jeonglee at lbl.gov>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 19 May 2021 04:54:48 +0000
Hey Han,
Tried to switch the localhost with the ip but still didn’t have any success.  I did also try to switch back that server.xml port to 8080 just to try but that didn’t help either.
<Connector connectionTimeout="20000" port="17665" protocol="HTTP/1.1" redirectPort="8443"/>
I will double check but caget,camonitor, caput seem to work fine from the PC to the same PC that has the archiver from what I remember.  I made sure the env variables are set on the client PC correctly.
Sent: Tuesday, May 18, 2021 12:12 PM
To: Manoussakis, Adamandios <manoussakis1 at llnl.gov>
Subject: Re: Archiver Appliance mgmt tomcat issue
Hi Adam,
Please change all localhost to your IP address, which you are using. And let me know what it will be.
Best,
Han
On Tue, May 18, 2021 at 12:11 PM Manoussakis, Adamandios <manoussakis1 at llnl.gov> wrote:
Hi Han,  I am just running one appliance in the archiver.
<?xml version='1.0' encoding='utf-8'?>
  Took the contents from single\_machine\_install.sh, and modified
  them according to our configuration.
<appliances>
   <appliance>
     <identity>appliance0</identity>
     <cluster_inetport>localhost:16670</cluster_inetport>
     <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
     <engine_url>http://localhost:17666/engine/bpl</engine_url>
     <etl_url>http://localhost:17667/etl/bpl</etl_url>
     <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
     <data_retrieval_url>http://localhost:17668/retrieval</data_retrieval_url>
   </appliance>
</appliances>
Sent: Tuesday, May 18, 2021 10:49 AM
Hi Adam,
Can you share your appliances.xml file? I want to see how you define them.
Best,
Han
On Tue, May 18, 2021 at 9:46 AM Manoussakis, Adamandios via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi Andrew,
Sorry for the confusion on the ips, the internal network we run this on does route properly. I am able to ping the corresponding computers and also we have another web server running that I am able get to.  I don’t think it’s the web browser or Phoebus, since I have tried just doing direct queries through python and not getting a response either.  I asked our IT again and there shouldn’t be anything blocking.
On May 18, 2021, at 8:23 AM, Johnson, Andrew N. <anj at anl.gov> wrote:
 HI Adam,
On May 18, 2021, at 2:01 AM, Manoussakis, Adamandios via Tech-talk <tech-talk at aps.anl.gov> wrote:
I am trying to figure out why I cannot access the front end interface of the archiver (192.168.3.50:17665/mgmt/ui/index.html) from another subnet.  Locally it works perfectly fine, able to archive PVs and retrieve with Phoebus for example or even using python.  When I try to get the web page to serve up on another PC that is not on the same subnet 192.168.2.25(PC) and 192.168.3.50(Archiver) for example it seems like the request gets stuck.  Some possible debugging has led to the JS not being loaded properly on the web browsers but I have looked for anything that would block on the network and cant seem to find any issue.
The IP addresses that you are using (192.168.*.*) are in the Private IP range, and are often not routable (at least when it comes to transit over the public internet). Do you know for sure that your routers are properly configured to pass packets between these subnets? Can you ping between them (both ways) and make some kind of a TCP connection (e.g. ssh or telnet) with devices in the other subnet?
I know nothing about the internals of the Archiver Appliance, tomcat, or the Java network stack, but it’s conceivable that something there (or even in a firewall) might also be preventing packets from the other private network from being delivered or sent.
Just an idea, I might be completely wrong though.
- Andrew
Complexity comes for free, simplicity you have to work for.
Jeong Han Lee, Dr.rer.nat.
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
Re: Archiver Appliance mgmt tomcat issue Jörn Dreyer via Tech-talk
Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Re: Archiver Appliance mgmt tomcat issue Johnson, Andrew N. via Tech-talk
Re: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Re: Archiver Appliance mgmt tomcat issue Han Lee via Tech-talk
RE: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Prev: RE: Utilizing StreamDevice in conjunction with sockets Mark Rivers via Tech-talk
Next: Re: Archiver Appliance mgmt tomcat issue Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Prev: Re: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
ANJ, 19 May 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
