1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: EPICS stopped
To: "'Tagger, Jueri'" <[email protected]>
Date: Wed, 19 May 2021 16:11:36 +0000
Can you type ^C to abort the casr command?  It could be a deadlock.  If that works then type
epicsMutexShowAll 1
several times and see if the same mutexes are always locked.   That is the symptom of a deadlock.
From: Tech-talk <[email protected]> On Behalf Of Tagger, Jueri via Tech-talk
Sent: Wednesday, May 19, 2021 11:04 AM
To: [email protected]
Subject: EPICS stopped
We have suddenly situation we can no longer connect to ca channels, (while the existing connections are served)
casr 4
181888 bytes allocated
       Send Lock:
           epicsMutexId 0x7f3978036420 source ../../../src/ioc/rsrv/caservertask.c line 1231
       Put Notify Lock:
           epicsMutexId 0x7f3978036450 source ../../../src/ioc/rsrv/caservertask.c line 1232
       Address Queue Lock:
           epicsMutexId 0x7f3978036480 source ../../../src/ioc/rsrv/caservertask.c line 1233
       Event Queue Lock:
           epicsMutexId 0x7f39780364b0 source ../../../src/ioc/rsrv/caservertask.c line 1234
       Block Semaphore:
           epicsEvent 0x7f3978010c90: full
    pthread_mutex = 0x7f3978010c90, pthread_cond = 0x7f3978010cb8
    TCP client at 10.0.153.12:54302 'box64-3':
       User 'rose', V4.13, Priority = 0, 75 Channels
       Task Id = 0x7f397803c750, Socket FD = 44
       2262.05 secs since last send, 2262.04 secs since last receive
       Unprocessed request bytes = 424, Undelivered response bytes = 0
       State = up
Then the output stopped …. no response any more on the console
EPICS_BASE=base-3.15.8
Any ideas?
J. Tagger
NSLS-II=
RE: EPICS stopped Tagger, Jueri via Tech-talk
Prev: EPICS stopped Tagger, Jueri via Tech-talk
Next: RE: EPICS stopped Tagger, Jueri via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
