1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux
From: "Pearson, Matthew R. via Tech-talk" <[email protected]>
To: junkes <[email protected]>
Date: Thu, 20 May 2021 14:43:03 +0000
I think I came across the same issue recently on RHEL8. There was a recent Asyn build option added, that you can set in CONFIG_SITE (or CONFIG_SITE.local):
TIRPC=YES
Which changes the include file search path to /usr/include/tirpc/
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of junkes via Tech-talk
Sent: Thursday, May 20, 2021 10:22 AM
To: Tech talk <[email protected]>
Subject: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux
I am in the process of cross-compiling EPICS7 for powerpc64-fsl-linux.
epics-base works great, also already some support-modules like sncseq, sscan, calc, busy …
Now I just fail with asyn on the vxi11 part.
rpc/rpc.h can only be found on the yocto-sysroot under usr/include/tirpc. Also I don't see any rpc-support like rpcgen etc..
That may also be due to how it was built with yocto. But this part I have not yet understood and I use
recipes from ESS and am quite happy where I have now arrived with their help ;-)
/opt/ifc14xx/2.6-4.14/sysroots/x86_64-fslsdk-linux/usr/bin/powerpc64-fsl-linux/powerpc64-fsl-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API   -D_ppc_64_ --sysroot=/opt/ifc14xx/2.6-4.14/sysroots/ppc64e6500-fsl-linux -mhard-float -mcpu=e6500  -DUNIX  -Dlinux      -O3   -Wall -Werror-implicit-function-declaration     -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC -DHAVE_CALCMOD -DHAVE_DEVINT64   -m64 --sysroot=/opt/ifc14xx/2.6-4.14/sysroots/ppc64e6500-fsl-linux -mhard-float -mcpu=e6500 -pipe -feliminate-unused-debug-types      -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         -I/home/yocto/EPICS/epics-support/seq-2.2.8/include -I/home/yocto/EPICS/epics-base/include/compiler/gcc -I/home/yocto/EPICS/epics-base/include/os/Linux -I/home/yocto/EPICS/epics-base/include   -I/home/yocto/EPICS/epics-support/sscan/include   -I/home/yocto/EPICS/epics-support/calc/include  -I/home/yocto/EPICS/epics-support/autosave/include/os/Linux -I/home/yocto/EPICS/epics-support/autosave/include   -I/home/yocto/EPICS/epics-support/busy/include         -I/home/yocto/EPICS/epics-support/motor/include           -c vxi11core_xdr.c
In file included from vxi11core_xdr.c:6:
vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory
#include <rpc/rpc.h>
compilation terminated.
Is there a variable/flag I can use to keep the vxi11 stuff out of the build process of asyn?
Danke Heinz
Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Hu, Yong via Tech-talk
asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux junkes via Tech-talk
Prev: asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux junkes via Tech-talk
Next: Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
