1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: PVAccess equivalent to EPICS_CAS_INTF_ADDR_LIST environment variable question
From: "White, Greg via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>
Cc: "Hanwell, Marcus" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 20 May 2021 17:03:59 +0000
Maybe see also "pvAccess Configuration (Excel)” [1]. You can find it in the sidebar of the old EPICS 4 WG homepage under “DEVELOPMENT” [2]. -Greg
[1] http://epics-pvdata.sourceforge.net/pvAccessConfig.xlsx
[2] http://epics-pvdata.sourceforge.net/index.html
> On May 20, 2021, at 1:13 AM, Ralph Lange via Tech-talk <[email protected]> wrote:
> On Wed, 19 May 2021 at 21:50, Wlodek, Jakub via Tech-talk <[email protected]> wrote:
> Is there an equivalent environment variable for PVA that will have it only bind to the specified interface?
> Yes, there is.
> Obviously not documented well and/or prominently enough. I found the best comprehensive list in the PVXS documentation:
> https://mdavidsaver.github.io/pvxs/server.html#configuration
> Cheers,
> ~Ralph
Re: [EXTERNAL] PVAccess equivalent to EPICS_CAS_INTF_ADDR_LIST environment variable question Hartman, Steven via Tech-talk
PVAccess equivalent to EPICS_CAS_INTF_ADDR_LIST environment variable question Wlodek, Jakub via Tech-talk
Re: PVAccess equivalent to EPICS_CAS_INTF_ADDR_LIST environment variable question Ralph Lange via Tech-talk
Prev: Re: EPICS stopped Hu, Yong via Tech-talk
Next: Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: PVAccess equivalent to EPICS_CAS_INTF_ADDR_LIST environment variable question Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] PVAccess equivalent to EPICS_CAS_INTF_ADDR_LIST environment variable question Hartman, Steven via Tech-talk
