1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: SNMP in EPICS
From: Tomasz Brys via Tech-talk <[email protected]>
Date: Fri, 21 May 2021 08:13:06 +0000
I have a problem how to implement SNMP protocol in EPICS.
I want to keep MIB file somewhere in the module, not in the /usr/share/snmp directory.
If I run snmpwalk I can:
snmpwalk -v2c -M +/vagrant/modules/e3-M300_GPS/M300_GPS/M300_GPSApp/MBG-SNMP-MIB -m All -c comm 192.168.XXX.XXX MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState
and I get output:
MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState.1 = INTEGER: synchronized(1)
How should I define my record in Db?
I did it like that:
record(longin, "$(P)$(R)RefclockState"){
  field(DESC, "Status of GPS refclock")
  field(DTYP, "Snmp")
  field(SCAN, "5 second")
  field(INP,  "@$(HOST) $(COMMUNITY) $(MIB)::mbgLtNgRefclockState Integer: 10")
Where:
$(HOST) = 192.168.XXX.XXX – this is of course fake address
$(COMMUNITY) = -c comm
$(MIB) = MBG-SNMP-LTNG-MIB
But I got error:
devSnmp: error parsing '192.168.XXX.XXX -c comm MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState Integer: 10'
         format is 'host community oidname mask maxdatalength [set_format/special]'
Error (511,511) PV: P:R:RefclockState devSnmpLi (init_record) bad parameters
Any help how I can do this?
Best regards
Tomasz Brys
European Spallation Source ERIC
Re: SNMP in EPICS Priller, John via Tech-talk
Re: SNMP in EPICS Pierrick M Hanlet via Tech-talk
Re: SNMP in EPICS Dunning, Michael via Tech-talk
Prev: RE: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Next: Re: SNMP in EPICS Priller, John via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Modbus & asynManager::queueLockPort queueRequest failed: port not connected Mark Rivers via Tech-talk
