1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: "Starter Kit" for learning EPICS?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Feister, Scott" <[email protected]>
Date: Tue, 25 May 2021 11:04:05 -0500
On 05/24, Feister, Scott via Tech-talk wrote:
> 2x Pynq-Z2 (for simple input/output)
> Resistors, potentiometers, LEDs, etc (simple inputs/outputs)
> 2x PC with Linux (for central control and data storage)
> 1x managed switch for networking
> Various ethernet cables
> Any other suggestions to get my students' feet wet with experimenting with and learning EPICS? Thanks!
Why two PCs?  I'm sure you could do fine with just one.  (But maybe
that's an intentional decision to demonstrate something?)
Why does the switch need to be managed?  It would probably be cheaper
if unmanaged.  (But maybe the prices have come down such that it's an
insignificant difference now?)
I don't know anything about the Pynq-Z2; is there an EPICS driver for
it?  If not, something else that comes to mind that you might consider
would be some USB devices from Measurement Computing.  Mark Rivers
has written EPICS drivers for some of them in his EPICS module called
measComp:
  https://github.com/epics-modules/measComp
Lewis
"Starter Kit" for learning EPICS? Feister, Scott via Tech-talk
Prev: Re: Re: How to set bo PV to zero when starting Modbus IOC Mark Rivers via Tech-talk
Next: Re: using autosave, iocInit hangs Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: "Starter Kit" for learning EPICS? Fujita Jiro via Tech-talk
Next: How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
