1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: asyn bo record staying in INVALID DRIVER UDF
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 27 May 2021 16:12:51 +0200
Hej Ralph,
I think it is the same-
camonitor, second round:
IOC:m6-OpenClutch 2021-05-27 15:51:06.243006 Closed UDF INVALID
IOC:m6-OpenClutch.UDF 2021-05-27 15:51:06.243006 0 UDF INVALID
IOC:m6-OpenClutch.STAT 2021-05-27 15:51:06.243006 UDF UDF INVALID
IOC:m6-OpenClutch.SEVR 2021-05-27 15:51:06.243006 INVALID UDF INVALID
[snipped warnings because of multihomed]
And this is dbpr IOC:m6-OpenClutch 10
ACKS: NO_ALARM ACKT: YES ASG : ASP : PTR (nil) BKLNK: ELL 0 [(nil) .. (nil)] BKPT: 00 COSV: NO_ALARM DESC: motor DISA: 0 DISP: 0 DISS: NO_ALARM
DISV: 1             DOL : CONSTANT      DPVT: PTR 0x1030ca0
DSET: PTR 0x7fb1485072c0 DTYP: asynInt32 EVNT: FLNK: CONSTANT HIGH: 0 IVOA: Continue normally IVOV: 0 LALM: 0 LCNT: 0 LSET: PTR 0xf143d0 MASK: 0 MLIS: ELL 4 [0x7fb11802fb38 .. 0x7fb11802fc40]
MLOK: b0 e8 fa 00 00 00 00 00           MLST: 0
NAME: IOC:m6-OpenClutch                  NSEV: NO_ALARM
NSTA: NO_ALARM OLDSIMM: NO OMSL: supervisory ONAM: Open
ORAW: 0             ORBV: 0             OSV : NO_ALARM
OUT : INST_IO @asyn(MCU1,6)OpenClutch PACT: 0 PHAS: 0 PINI: NO PPN : PTR (nil) PPNR: PTR (nil) PRIO: LOW PROC: 0 PUTF: 0 RBV : 0 RDES: PTR 0xb6e100 RPRO: 0 RPVT: PTR 0x1030c70 RSET: PTR 0x7fb146f9e860 RVAL: 0 SCAN: Passive SDIS: CONSTANT SDLY: -1 SEVR: INVALID SIML: CONSTANT SIMM: NO SIMPVT: PTR (nil) SIMS: NO_ALARM SIOL: CONSTANT SPVT: PTR (nil) SSCN: <nil> STAT: UDF TIME: 2021-05-27 15:51:06.243005887 TPRO: 0 TSE : 0 TSEL: CONSTANT UDF : 0 UDFS: INVALID
VAL : 0             WDPT: PTR (nil)     ZNAM: Closed        ZSV : NO_ALARM
/Torsten
On 5/27/21 2:21 PM, Ralph Lange via Tech-talk wrote:
Hi Torsten,
On Thu, 27 May 2021 at 12:53, Torsten Bögershausen via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
    Asyn-Experts,
    I am chasing an interesting problem.
    For a motor, we have a clutch that can be opened under very
    special conditions, say service mode.
    We define it like this:
    The alarm seem to go away, if the record is processed one more time.
    (by disconnecting the IOC from the controller and re-establishing the
    connection).
    Is this a know phenomena ?
    Anything that can be done ?
How does the setup behave when using Channel Access?
(To see if it is a problem on the ASYN side or the QSRV side of the database.)
Cheers,
~Ralph
Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
Prev: Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Next: Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
