1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: asyn bo record staying in INVALID DRIVER UDF
To: 'Torsten Bögershausen' <[email protected]>, Ralph Lange <[email protected]>, "'Johnson, Andrew N.'" <[email protected]>
Date: Fri, 28 May 2021 15:22:03 +0000
Hi Torsten,
I created a new modified version of testAsynPortDriver.  It reproduces your problem exactly.  I added a new Clutch bo record and parameter.  That value does not get set with setIntegerParam in the constructor, it first gets set when the poller thread has slept for 2 seconds.  That means the initial readback will return asynInvalid, and we should and do see UDF=1, STAT=UDF, SEVR=INVALID right after iocInit.
2 seconds later the poller thread sets the value to 1 and does the callbacks.  The record processes, and UDF=0 and VAL=1, and TIME=2 seconds after poller thread was created, exactly as expected.  However the record still has STAT=UDF and SEVR=INVALID, which is not what we expect.
2 seconds later the poller thread sets the value back to 0 and again does the callbacks.  The record processes, and UDF=0 and VAL=0, and TIME=2 seconds after the previous time the record processed, exactly as expected.  This time the record has STAT=NO_ALARM and SEVR=NO_ALARM, which is what we expect.
The question is why do STAT and SEVR appear to be incorrect the first time the record processes?
I have created a new Github issue for this, https://github.com/epics-modules/asyn/issues/136.  I have also created a new debug_udf branch of asyn on Github with this modified version of testAsynPortDriver.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Torsten Bögershausen via Tech-talk
Sent: Friday, May 28, 2021 4:29 AM
To: Ralph Lange <[email protected]>; EPICS Tech Talk <[email protected]>
Subject: Re: asyn bo record staying in INVALID DRIVER UDF
Hej Ralph,
I don't know if I understand the question 100%.
So let me try to explain, what is happening:
In st.cmd, we start a poller thread, talking to the hardware (=motion controller unit, MCU in ESS speach) (And the poller is a model 3 motordriver)
When the poller reads the value from the MCU, it calls
               setIntegerParam(axisNo, function,  newValue);
               callBacksNeeded = 1;
and later
     if (callBacksNeeded) {
       callParamCallbacks();
When the IOC is not yet started, the callbacks are blocked somewhere.
But the setIntegerParam() succeeds and the new value is in the asyn parameter libray.
The bo record does this, once the record need to be initialized:
static long initBo(boRecord *pr)
     devPvt *pPvt;
     int status;
     epicsInt32 value;
     status = initCommon((dbCommon *)pr,&pr->out,
         processCallbackOutput,interruptCallbackOutput,
interruptCallbackEnumBo,
         2, (char*)&pr->znam, NULL, &pr->zsv);
     if (status != INIT_OK) return status;
     pPvt = pr->dpvt;
     /* Read the current value from the device */
     status = pasynInt32SyncIO->read(pPvt->pasynUserSync,
                       &value, pPvt->pasynUser->timeout);
     if (status == asynSuccess) {
         pr->rval = value;
         return INIT_OK;
     return INIT_DO_NOT_CONVERT;
So when the record can read a value from the paramlib,
pasynInt32SyncIO() return asynSuccess, the value
is put into the record and everything is fine.
But, there is a race:
When the iocInit() is faster than the poller, the record
is initialized in initBo(), but kept in
"INVALID DRIVER UDF" alarm state.
Later (could be milliseconds, seconds, whatever)
when the poller can talk to the MCU, it will write the value
into the paramlibrary (as before).
(The dev support will resset UDF to 0)
A record processing is triggered and executed.
The new value is in the record, but the alarm status stays,
until the record is processed another time:
static long processBo(boRecord *pr)
     devPvt *pPvt = (devPvt *)pr->dpvt;
     int status;
     epicsMutexLock(pPvt->devPvtLock);
     if(pPvt->newOutputCallbackValue && getCallbackValue(pPvt)) {
         /* We got a callback from the driver */
         if (pPvt->result.status == asynSuccess) {
             pr->rval = pPvt->result.value;
             pr->val = (pr->rval) ? 1 : 0;
             pr->udf = 0;
If I change the code like this:
     int status;
       fprintf(stdout, "%s/%s:%d %s pPvt->result.status=%d\n",
                      __FILE__, __FUNCTION__, __LINE__,
                      pr->name, pPvt->result.status);
             if (pr->udf) {
                 pr->udf = 0;
                 pr->nsta = 0;
                 pr->nsev = 0;
Everything is fine.
Does this explain anything ?
Thanks to everybody
/Torsten
On 5/28/21 11:02 AM, Ralph Lange via Tech-talk wrote:
> Might that be related to the initial readback being an asynchronous
> process(ing)?
> The whole idea of doing an initial readback as part of record
> initialization is based on the assumption that the readback is
> immediate, i.e. synchronous.
> If it is asynchronous and the device answer is only accepted after the
> equivalent of interruptAccept being true, the timing and order of things
> may be pretty different. In those cases, initial readback has to be done
> as part of PINI processing, as that runs late enough and works with
> asynchronous device access. In case that asyn:READBACK is set, the read
> request can be done as part of the record initialization if the device
> answer is delayed long enough (or queued) to be processed after
> interruptAccept. Dropping the device answer would leave the record with
> UDF cleared (from the silent initial readback) but without processing
> (as the device answer was lost), which resembles what Torsten is seeing,
> doesn't it?
> Cheers,
> ~Ralph
asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
RE: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Prev: Re: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
Next: Re: Issue with FPGA based encoder box when running with EPICS 7.0.5 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Next: Re: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
