1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS_CA_ADDR_LIST for getting remote PVs
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Tue, 1 Jun 2021 17:47:49 +0000
export EPICS_CA_ADDR_LIST=<VM IP>  should get you to one IOC.
If you have multiple IOCs on that host, you'll have to either
export EPICS_CA_ADDR_LIST=<broadcast to subnet of the VM>
and assert that broadcasts actually get there, or run a CA gateway on the VM and then set the addr list to the gateway.
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Tuesday, June 1, 2021 1:21 PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] EPICS_CA_ADDR_LIST for getting remote PVs
Hello all.
i have some IOCs running in a Debian 9.13 virtual machine. I am accessing it via a Debian 9.13 container which is inside my Ubuntu 20.04. The VM and container are on different nets and i am accessing the VM via ssh.
I thought the command
would make my container be able to caget the PVs that are on the VM, but i found the following statement on tech-talk records:
- If you set EPICS_CA_ADDR_LIST to the specific IOC machine then by default it will not work if that machine is running more than one IOC.  But there are ways to work around that.
and that is exactly my case, but i didnt find anything about how to go around that. Does anyone know how can i access PVs from another machine that runs multiple IOCs?
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: EPICS_CA_ADDR_LIST for getting remote PVs Ralph Lange via Tech-talk
EPICS_CA_ADDR_LIST for getting remote PVs Marco A. Barra Montevechi Filho via Tech-talk
Prev: EPICS_CA_ADDR_LIST for getting remote PVs Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: EPICS web visualization Simon Rees via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: EPICS_CA_ADDR_LIST for getting remote PVs Ralph Lange via Tech-talk
