1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Advantages of running IOC on FPGA
From: Pete Jemian via Tech-talk <[email protected]>
To: <[email protected]>
Date: Wed, 2 Jun 2021 10:55:59 -0500
Isn't DMA a distinct advantage with running EPICS and FPGA on the same silicon? Gives hardware-level access to data and allows for interrupts to the OS from the FPGA.
Pete
(The one who does not program FPGA, just listens to others.)
On 6/2/2021 10:49 AM, Till Straumann via Tech-talk wrote:
Raj.
Regarding network security: most facilities use firewalls and isolated network segments
for security.
This is orthogonal to your question - EPICS is not particularly secure (but neither is your
proprietary UDP protocol going to be).
Re. maintenance: yes, you will have to maintain EPICS on an additional target platform. However, the zynq/arm target is well supported and I wouldn't expect any particular problems. On the upside: you *only* have to support EPICS and won't have to maintain/support
your proprietary solution in addition to EPICS.
Again: communicating with hardware and providing a standardized networking interface
(channel-access) is pretty much the definition of an IOC under EPICS.
If IOC system load due to many clients is a concern then that is traditionally mitigated with
a channel-access gateway.
HTH
- Till
On 6/1/21 11:17 PM, Kunjir, Shriraj wrote:
Hi Till,
Thank you for your response. Could you please elaborate on the maintenance and network security aspect of such an LLRF controller when it runs IOC on its PS side Linux?
We are evaluating the potential of running IOC on our Zynq based LLRF controllers.
*From: *Till Straumann via Tech-talk <mailto:[email protected]>
*Sent: *Tuesday, June 1, 2021 5:09 PM
*To: *[email protected] <mailto:[email protected]>
*Subject: *Re: Advantages of running IOC on FPGA
*[EXTERNAL] This email originated from outside of FRIB*
I'd say that the 'traditionally' an IOC *is* actually executed on a front-end controller with EPICS taking care of networking and control-system integration. This is what EPICS was originally designed for. (IOCs running on embedded VME computer that
were directly talking to hardware).
When you don't run an IOC on the Zynq then you have to invent your proprietary UDP protocol, write some sort of server that does I/O on the Zynq and some protocol
translation to EPICS on the 'IOC server'.
FPGA <-> ZYNQ (I/O -> UDP) <-> ethernet <-> server (UDP -> EPICS)
You can eliminate all this effort simply by running an IOC on the zynq.
Cheers
- Till
On 6/1/21 10:14 PM, Kunjir, Shriraj via Tech-talk wrote:
Hello,
Could you please help in understanding the advantages of running IOC server on LLRF Zynq FPGA over the traditional method of a standalone IOC server connecting to LLRF FPGA via UDP. Thank you
Raj
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
      Education is the one thing for which people
         are willing to pay yet not receive.
Advantages of running IOC on FPGA Kunjir, Shriraj via Tech-talk
Re: Advantages of running IOC on FPGA Till Straumann via Tech-talk
RE: Advantages of running IOC on FPGA Kunjir, Shriraj via Tech-talk
Prev: Re: Advantages of running IOC on FPGA Till Straumann via Tech-talk
Next: RE: AreaDetector stream encoding Daykin, Evan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: EPICS Collaboration Meeting - New Date Announced EPICS Spring 2021 via Tech-talk
