1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: arv-tool-0.8 with FLIR-Blackfly camera
From: "Wang, SuYin Grass via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Date: Thu, 3 Jun 2021 18:13:50 +0000
Hi Mark,
The network is an ethernet port with static IP address. The cable is connecting directly from camera to the laptop.
eno2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 9000
        inet 192.168.1.5  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::2101:2192:d0e8:15fe  prefixlen 64  scopeid 0x20<link>
        ether 74:78:27:47:50:46  txqueuelen 1000  (Ethernet)
        RX packets 53  bytes 8866 (8.6 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 18465  bytes 3934095 (3.7 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 16  memory 0xcc300000-cc320000
Thank you!
Grass
Sent: Thursday, June 3, 2021 1:03 PM
To: Wang, SuYin Grass <[email protected]>
Cc: [email protected] <[email protected]>
Hi Grass,
I am including tech-talk in this, I forgot to CC tech-talk in my original reply.
> I am not sure why does the arv-tool-0.8 can get the camera name correct, but then complained "Invalid Genicam data"
It sounds like perhaps it is a network configuration problem, for example jumbo packets being enabled on the NIC but not on some intermediate switch or something.  What is the network path from the Linux machine to the camera?
Sent: Thursday, June 3, 2021 12:55 PM
To: Mark Rivers
Cc: Wang, SuYin Grass
Hi Mark,
I also tried to remove the fake camera, and I got the same error.
This camera works fine with Spinnaker SDK in windows machine.
I also try to ignore the arv-tool, just use the database existed. (st.cmd.BlackflyS_70S7M attached)
areaDetector-R3-11/ADAravis/iocs/aravisIOC/iocBoot/iocAravis/st.cmd.BlackflyS_70S7M
but the aravisConfig cannot find this camera. I am not sure why does the arv-tool-0.8 can get the camera name correct, but then complained "Invalid Genicam data"
==================error from IOC===
# aravisConfig(const char *portName, const char *cameraName, int enableCaching, size_t maxMemory, int priority, int stackSize)
aravisConfig("ARV1", "FLIR-Blackfly S BFS-PGE-70S7M-19069593", 1, 0, 0, 0)
ADAravis: Looking for camera 'FLIR-Blackfly S BFS-PGE-70S7M-19069593'...
2021/06/03 12:42:40.399 ADAravis:makeCameraObject: No camera found, err=Invalid Genicam data
Thanks!
Grass
Sent: Thursday, June 3, 2021 10:51 AM
Subject: RE: arv-tool-0.8 with FLIR-Blackfly camera
Hi Grass,
There are database and opi screens for that camera in ADGenICam.  They are from Hinko Kocevar, so I think others are using that camera OK.
What happens if you eliminate the fake camera?  I have never tested with that.
What version of aravis are you using?
Can you put some other GigE camera on your network and see if arv-tool-0.8 works with that?
This is the output of arv-tool-0.8 on my Centos 8 system.  It is finding all of the cameras without the error you have.  I believe it is built using aravis 0.8.1.
[epics@viper ~]$ arv-tool-0.8
PointGrey-010AA71D (USB3)
Allied Vision Technologies-GC1380H (02-2142A)-02-2142A-06178 (164.54.160.58)
Allied Vision Technologies-GT1380 (02-2604A)-02-2604A-07008 (164.54.160.104)
Allied Vision Technologies-Manta G-507C (E0022705)-50-0503419258 (164.54.160.21)
Allied Vision Technologies-Manta G-507C (E0022705)-50-0503479241 (164.54.160.3)
Allied Vision Technologies-Manta_G-146C (E0020011)-50-0503317598 (164.54.160.62)
Point Grey Research-Blackfly BFLY-PGE-20E4C-13481965 (164.54.160.114)
From: Tech-talk <[email protected]> On Behalf Of Wang, SuYin Grass via Tech-talk
Sent: Thursday, June 3, 2021 10:35 AM
To: [email protected]
Subject: arv-tool-0.8 with FLIR-Blackfly camera
Hi Everyone,
Is anyone here using the "FLIR-Blackfly S BFS-PGE-70S7M" camera?
We decide to use ADAravis for our RHEL8 or RHEL7 machine.
I just installed arv-tool-0.8 on my laptop(RHEL8).
While the Aravis-Fake camera seems running fine, I got an error for my real camera (Invalid Genicam data).
(tutorial-env) bash-4.4$ ./arv-fake-gv-camera-0.8
(tutorial-env) bash-4.4$ ./arv-tool-0.8
Aravis-Fake-GV01 (127.0.0.1)
Failed to open device 'FLIR-Blackfly S BFS-PGE-70S7M-19069593': Invalid Genicam data
Is there anything we need to modify before running the arv-tool?
Thanks!
Grass
Re: arv-tool-0.8 with FLIR-Blackfly camera Mark Rivers via Tech-talk
arv-tool-0.8 with FLIR-Blackfly camera Wang, SuYin Grass via Tech-talk
Prev: Re: arv-tool-0.8 with FLIR-Blackfly camera Mark Rivers via Tech-talk
Next: Re: arv-tool-0.8 with FLIR-Blackfly camera Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
