1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Problems configuring alarms with PvaPy
From: "Veseli, Sinisa via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, KRL Baker - STFC UKRI <[email protected]>
Date: Mon, 7 Jun 2021 17:48:22 +0000
At the moment there is no automated handling of alarm values. You would have to do something like this (compared to your original code example):
bluegill2> diff s.py s.py.orig
48c48
< server.addRecord('counter', pv.copy())
> server.addRecord('counter', pv)
57,66d56
<         (severity, status, message) = (0, 0, 'ALL CLEAR')
<         if c >= pv['alarm_values.highAlarmLimit']:
<             (severity, status, message) = (pv['alarm_values.highAlarmSeverity'], 1, 'HIGH ALARM')
<         elif c >= pv['alarm_values.highWarningLimit']:
<             (severity, status, message) = (pv['alarm_values.highWarningSeverity'], 1, 'HIGH WARNING')
<         elif c <= pv['alarm_values.lowAlarmLimit']:
<             (severity, status, message) = (pv['alarm_values.lowAlarmSeverity'], 1, 'LOW ALARM')
<         elif c <= pv['alarm_values.lowWarningLimit']:
<             (severity, status, message) = (pv['alarm_values.lowWarningSeverity'], 1, 'LOW WARNING')
72,76d61
<             'alarm' : {
<             'severity' : severity,
<             'status' : status,
<             'message' : message
80d64
<         server.update(pv)
bluegill2>
I will add better alarm handling in the next release.
I hope this helps,
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
From: Tech-talk <[email protected]> on behalf of KRL Baker - STFC UKRI via Tech-talk <[email protected]>
Sent: Monday, June 7, 2021 8:20 AM
To: [email protected] <[email protected]>
Subject: Problems configuring alarms with PvaPy
Hello Tech-Talk,
I am working with PvaPy to create and update some PVs and am trying to work out how to configure the alarms for the pv.
I have created the object using the code below, which creates the ‘counter’ pv and updates the values (which I can see with a pvmonitor or a pvinfo).
         initial_time = time.time()
    seconds, nanoseconds = extract_seconds_and_nanoseconds_from_timestamp(initial_time)
    timestamp = PvTimeStamp(seconds, nanoseconds, 0)
    # configure display values
    display = PvDisplay(0, 10, 'Test Display', 'Test Format', 'units')
    # set up alarm - severity (0=NO_ALARM, 1=MINOR, 2=MAJOR, 3=INVALID, 4=UNDEFINED), status, message
    alarm = PvAlarm()
    alarm.setSeverity(0)
    alarm.setMessage('test alarm message')
    alarm_values = PvValueAlarm(FLOAT)
    alarm_values.setHighAlarmLimit(9)
    alarm_values.setLowAlarmLimit(2)
    alarm_values.setHighWarningLimit(8)
    alarm_values.setLowWarningLimit(3)
    alarm_values.setHighAlarmSeverity(2)
    alarm_values.setLowAlarmSeverity(2)
    alarm_values.setHighWarningSeverity(1)
    alarm_values.setLowWarningSeverity(1)
    alarm_values.setActive(True)
    pv = PvObject({
        'value': FLOAT,
        'timeStamp': timestamp,
        'display': display,
        'alarm': alarm,
        'alarm_values': alarm_values
        'timeStamp': timestamp.toDict(),
        'display': display.toDict(),
        'alarm': alarm.toDict(),
        'alarm_values': alarm_values.toDict()
    server = PvaServer()
    c = 0
    startTime = time.time()
    try:
        while True:
            time.sleep(1)
            if c == 11:
                c = 0
            seconds, nanoseconds = extract_seconds_and_nanoseconds_from_timestamp(time.time())
            epics_message = {
                'value': c,
                'timeStamp': {
                    'secondsPastEpoch': seconds,
                    'nanoseconds': nanoseconds
            pv.set(epics_message)
            c += 0.5
    finally:
        server.stop()
This creates a PV with the following structure:
    float value 10.5
    time_t timeStamp 2021-06-07 13:31:45.733
        long secondsPastEpoch 1623069105
        int nanoseconds 732768297
        int userTag 0
    display_t display
        double limitLow 0
        double limitHigh 10
        string description "Test Display"
        string format "Test Format"
        string units units
    alarm_t alarm
        int severity 0
        int status 0
        string message "test alarm message"
    valueAlarm_t alarm_values
       boolean active true
        float lowAlarmLimit 2
        float lowWarningLimit 3
        float highWarningLimit 8
        float highAlarmLimit 9
        int lowAlarmSeverity 2
        int lowWarningSeverity 1
        int highWarningSeverity 1
        int highAlarmSeverity 2
        byte hysteresis 0
As you can hopefully see from the code, I have set up the alarms with severity 0 (NO_ALARM) to begin with and set the severity of the warnings and limits to be MINOR and MAJOR (2 and 3).
However, using this set-up I would expect to see the alarm messages raised when the value of the PV approaches 0 or 10, but no alarm messages are displayed. The only time I am able to see messages is if I set the severity of the alarm object to be something other than 0, but this then raises alarm messages for all value states which is not the desired behaviour.
Is there something that I’m missing in the configuration of the alarms? Is there something that I need to set to ‘activate’ the logic behind the alarms?
Kathryn Baker (she/her)
Software Development for Accelerator Control Systems Graduate
Science and Technology Facilities Council
[email protected]
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
RE: Problems configuring alarms with PvaPy KRL Baker - STFC UKRI via Tech-talk
Prev: Problems configuring alarms with PvaPy KRL Baker - STFC UKRI via Tech-talk
Next: Going full PVA? Stainer Tom via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: Problems configuring alarms with PvaPy KRL Baker - STFC UKRI via Tech-talk
