1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Instructions on using manage-procs procServ and Conserver
From: "Smith, William via Tech-talk" <[email protected]>
Date: Fri, 11 Jun 2021 17:38:54 +0000
Hi!
I have been using procServ for a while to run my IOC’s in the background. There are now too many and I want to learn how to use manage-procs, part of procServUtils to create and start processes and configure the conserver.cf file to view those processes from conserver. Here’s what I’ve done:
-Installed procServ, and included the procServUtils in the build
-Installed conserver
-Set up an IOC that I have tested can start from the command line, or with procServer
If I go to the directory containing the st.cmd file and type:
manage-procs add -P 7010 -A -f sampleIOC1 ./st.cmd
I expect the IOC to start and be accessible on telnet port 7010. Instead I get the following message which I don’t understand:
Created symlink /home/emil/.config/systemd/user/multi-user.target.wants/procserv-sampleIOC1.service → /home/emil/.config/procServ.d/procserv-sampleIOC1.service.
Created symlink /home/emil/.config/systemd/user/procserv-sampleIOC1.service → /home/emil/.config/procServ.d/procserv-sampleIOC1.service.
Failed to start procserv-sampleIOC1.service: Unit procserv-sampleIOC1.service has a bad unit file setting.
See user logs and 'systemctl --user status procserv-sampleIOC1.service' for details.
If I look in that file, I get the following:
cat /home/emil/.config/procServ.d/procserv-sampleIOC1.service
[Unit]
Description=procServ for sampleIOC1
After=network.target remote-fs.target
ConditionPathIsDirectory=/home/emil/Apps/epics/R7.0.4.1/work/ioc/TEST/sampleIOC/iocBoot/iocsampleIOC
[Service]
Type=simple
ExecStart=None --user sampleIOC1
RuntimeDirectory=procserv-sampleIOC1
StandardOutput=syslog
StandardError=inherit
SyslogIdentifier=procserv-sampleIOC1
[Install]
WantedBy=multi-user.target
If I look at the systemd process that failed to start I get:
Jun 11 16:40:46 sissy-serv-02 systemd[29562]: /home/emil/.config/procServ.d/procserv-sampleIOC1.service:9: Executable "None" not found in path "/usr/local/sbin:/usr/local/bin:/usr/sbin:/us…..
Any idea what I am doing wrong?
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Re: Instructions on using manage-procs procServ and Conserver Michael Davidsaver via Tech-talk
Re: Instructions on using manage-procs procServ and Conserver Hu, Yong via Tech-talk
Prev: Re: EPICS 7 + RTEMS 5 Michael Davidsaver via Tech-talk
Next: Re: Instructions on using manage-procs procServ and Conserver Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
