Hello,
I'm trying to get the timestamp from another IOC (we will call it "IOC1") using the following DB records: record(stringin, "$(user):TimeStr") { field(DTYP, "Soft Timestamp")field(TSEL, "$(Y):Timestamp_from_IOC1.TIME CP MS") field(INP, "@%s") field(SCAN, ".2 second") } record(ao, "$(user):Time"){ field(DTYP, "asynInt32") field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))my_time") } record(calcout, "$(user):TimeCalc"){ field(OUT, "$(user):Time PP") field(CALC, "A") field(INPA, "$(user):TimeStr.VAL CP MS") field(PINI, "YES") } At the startup of IOC2 I am able to get the timestamp from IOC1 but only once. The PV "TimeStr" doesn't update. Can someone help me with this task? Thanks in advance, Adrián. This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
ANJ, 16 Jun 2021 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
